What do you think this Turbo H22A Accord is worth if put on Sale?
Old Sep 16, 2006 | 03:03 PM
autobot130's Avatar
Default What do you think this Turbo H22A Accord is worth if put on Sale?
1999 Honda Accord Coupe EX with 66k miles on the odometer. It has a JDM H22 motor that is fully built from the ground up that only has 5.8k miles on it. This car is built perfectly and nothing done sloppy... my belief is that if you're going to do it, then do it right the first time. Working A/C and power steering, no oil leaks whatsoever. Please email me for questions. I have a LOT of extras that go with the car, some stuff is brand new (as listed below).
More photos at http://www.cpixel.com/album_vi..._evil
JDM PRELUDE H22A SHORT BLOCK ASSEMBLED WITH IRON DUCTILE SLEEVES
ARIAS 8:5 COMPRESSION RATIO PISTONS AND FORGED RODS
NEW HONDA GENUINE OIL PUMP
NEW HONDA GENUINE WATER PUMP
NEW HONDA GENUINE TIMING BELT
ARP HEAD STUDS INSTALLED
NEW BEARINGS, MICROPOLISHED AND BALANCED ENGINE BLOCK
TITANIUM VALVE SPRINGS AND TITANIUM VALVE SPRING RETAINERS
PORT FLOW - 3 ANGLE VALVE JOB (INTAKE/EXHAUST, SURFACE, HOT TANK, NEW VALVE SEALS)
R&R ENGINE TENSIONER, HEAD GASKET
DRAG GEN III TURBO KIT W/ INTERCOOLER, CUSTOM PIPING W/ HIGH TEMP PAINT CHROME PAINT
TURBONETICS HYBRID T4/T3 TURBO
TIAL 40MM WASTE GATE
GREDDY TYPE-S BLOW OFF VALVE
RC ENGINEERING 550CC UPGRADED FUEL INJECTORS
EARLS KEVLAR - 10 OIL RETURN LINE W/ AN FITTINGS
QUAFE (LSD) LIMITED SLIP DIFFERENTIAL TRANSMISSION W/ NEW BEARINGS AND SHIMS
CLUTCH MASTERS - STAGE 5 CLUTCH
WALBRO 255PSI IN-TANK FUEL PUMP (GOOD FOR 400+HP)
GREDDY ELECTRONIC 60MM BOOST GAUGE (SILVER)
GREDDY ELECTRONIC 60MM EXHAUST GAS TEMP GAUGE (SILVER)
GREDDY ELECTRONIC 60MM AIR/FUEL RATIO GAUGE (SILVER)
MSD IGNITION AMPLIFIER AND COIL
DENZO IRIDIUM IK24 SPARK PLUGS WITH ARAMAKI WIRES
HONDATA INTAKE MANIFOLD GASKET
KOYO 3-CORE ALUMINUM RADIATOR
DUAL HIGH-SPEED SPAL RADIATOR FANS (PULL TYPE)
HONDA H23 MOTOR MANUAL TENSIONER CONVERSION KIT
AEM EMS - STANDALONE ENGINE MANAGEMENT
AEM FUEL PRESSURE REGULATOR W/ GLYCERINE GAUGE (SILVER)
AEM ADJUSTABLE CAM GEARS
AEM TRU-POWER PULLEY SYSTEM (UNDERDRIVE PULLEYS)
AEM 2.5 BAR MAP SENSOR
AEM WIDEBAND UEGO O2 SENSOR CONTROLLER MODULE W/ GAUGE (UNOPENED)
AEM HIGH VOLUME FUEL RAIL
MOROSO HEADER AND EXHAUST WRAP (NEW DEI EXHAUST WRAP INCLUDED)
HKS - CIRCLE EARTH GROUND WIRE SYSTEM KIT
APEXi - N1 SERIES DUAL EXHAUST WITH CUSTOM 3" PIPING
BREMBO SLOT/DRILLED ROTORS (FRONT/REAR DISCS)
SPARCO TORINO 2 FRONT DRIVER/PASSENGER SEATS (BRAND NEW) W/ SPARCO MOUNTING BRACKETS
PHILIPS HID 8000K TEMPERATURE HEADLIGHT CONVERSION KIT (BRAND NEW IN BOX)
ACCORD HEADLIGHTS W/ BLACK HOUSING (BRAND NEW IN BOX)
SEIBON EVO CARBON FIBER HOOD
SPRINT 2.5" LOWERING SUSPENSION KIT INSTALLED (ADDITIONAL NEW COILOVER SET INCL.)
RACING HART TYPE C5 WHEELS - 18 x 8.5
PIONEER GEX-P7000TV TV TUNER SYSTEM CONTROLLER
PIONEER AVX-P7000CD ENTERTAINMENT SYSTEM W/ 7" LCD SCREEN
PIONEER DEH-P9300 CD/AM/FM PRIMARY HEADUNIT
Old Sep 16, 2006 | 03:14 PM
YeuEmMaiMai's Avatar
what is that line on the right side of the bumper and why are the kick panel missing from passenger side?
dual exhaust?
it is not worth anymore than a stock accord
Old Sep 16, 2006 | 04:56 PM
hondadude's Avatar
Default Re: What do you think this Turbo H22A Accord is worth if put on Sale? (autobot130)
I know exactly what it's worth;
Whatever the market will bear!!!
I'll bid $200 for a parts car
Old Sep 16, 2006 | 06:09 PM
shadow_ridge's Avatar
Default Re: What do you think this Turbo H22A Accord is worth if put on Sale? (hondadude)
ahh dr. evil.... humm i clicked on the link and saw cpixel... i remember tons of getto kids looking up that site in school.
well anyways, how much did you bottom head unit cost you? im looking for something like that to match my setup.
Old Sep 16, 2006 | 07:45 PM
hdawg06's Avatar
What kind of numbers does that put down?
Old Sep 16, 2006 | 08:19 PM
gianinline's Avatar
I would say the car could cost from 8k to 11k....
Old Sep 16, 2006 | 11:02 PM
raceACCORDingly's Avatar
part it out.
katzenjammer84
Aug 15, 2011 12:57 PM
lk5545
Apr 25, 2009 08:59 AM
turbo_d
Oct 29, 2008 06:49 PM
autobot130
Oct 7, 2006 08:20 AM
