Noob Question: Firing sequence
Old Sep 16, 2006 | 01:15 PM
delguiner's Avatar
Default Noob Question: Firing sequence
I think i might have placed my wires wrong on the lude cause it's running like total a$$. how does the sequence go?? Looking at the engine is it 4-3-2-1 going from right to left? how are they placed on the distributor cap?
i know this is a stupid question, just bare with me. I'm a tad bit lost.
Old Sep 16, 2006 | 02:30 PM
99_SH's Avatar
Default Re: Noob Question: Firing sequence (delguiner)
Firing order of 1-3-4-2. Drivers side is Cyl #1, and goes right to left.
On the distributor, starting from the coil wire, go 1-3-4-2, clockwise
Old Sep 16, 2006 | 10:23 PM
crxklrlude's Avatar
in most cases the cyl. numbers start 1 at the water pump end.
as that being the front of the engine
Old Sep 17, 2006 | 12:03 AM
Silver Surfer's Avatar
next time mark where they came off.....this saying pretty much goes for anything you replace on any project......good rule of thumb to work by
Old Sep 17, 2006 | 07:28 AM
mgags7's Avatar
not all people have internal coil....there is a dot on the distributor cap at the cylinder #1 spot, just a 1/4" dot....that goes for any cap...
Old Sep 17, 2006 | 09:35 AM
delguiner's Avatar
could i have maybe done something wrong? i hooked it up wrong once or twice and it idled REALLY bad, so i shut off the engine. Everything is hooked up right, and now i hear this popping sound coming from the exhaust! im able to drive and stuff, but it's not totally smooth... could i have screwed up the plugs or something? it's a little hesitant at lower RPM's... i changed the plugs 2 months ago (ngk iridiums)
thanks
Modified by delguiner at 2:36 PM 9/17/2006
Old Sep 17, 2006 | 01:23 PM
99_SH's Avatar
Default Re: (delguiner)
It would help if you told us what you had done before you started observing these problems. Just a plug change? t-belt?, ??
vern
Jun 22, 2009 07:00 AM
wakaranai
14
Jan 19, 2008 01:26 PM
Blk00EJ8
Apr 28, 2007 01:27 PM
Doopreme
Feb 17, 2006 09:36 AM
