Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
squeeky clutch
Old Sep 16, 2006 | 09:41 AM
Jer'rome's Avatar
Default squeeky clutch
Even though ive fixed this problem before , the fukin thing now STILL squeels . I scearched 7th gen found the cause, so i took apart the the clutch cylinder and lubed it and was good, now recenly with all the rain its back and with a vengence, i used lithum grease this time and nothing seems to stop it. any help would be appreciated
Old Sep 16, 2006 | 12:19 PM
Miracle's Avatar
Default Re: squeeky clutch (Crunk'd)
According to Honda, the problem of the squeak is the spring on the back side of the piston inside the master cylinder rubs against the bore of the cylinder, and causes it to squeak. Also, according to Honda, the master cylinder needs to be replaced according to their TSB bulletin.
Take it to a dealership and see if they will take care of you before spending any money.
Old Sep 16, 2006 | 12:29 PM
Jer'rome's Avatar
Default Re: squeeky clutch (.Red.EM2)
thanks man!!
collkid
Feb 23, 2021 03:20 PM
majinx4
Jun 14, 2006 05:46 AM
Schurke
Nov 24, 2005 05:16 PM
B18PoweredCivic
Sep 24, 2003 10:58 AM
