Grounding pts
Old Sep 16, 2006 | 01:41 AM
garyc17's Avatar
Default Grounding pts
Hi, I have a EK hatch. Anyone can tell me the exact locations of all the grounding points that can relate to fuel pump operation? Is there a ground point at the fuel pump itself? I have been having inconsistant fuel pump priming on startup and would like to get this ground point fixed ASAP. I have sanded down the T-stat ground point, valve cover point, got new battery terminals, left and right ground points behind the headlights. Where else did I over look? Are there critical points in the car?
Old Sep 20, 2006 | 08:42 AM
garyc17's Avatar
I am sure someone here can help.
Old Sep 20, 2006 | 09:09 AM
bluescrews's Avatar
Is the Main Fuel Relay underneath the dash (driver side) in good working condition? Do you hear a "tick" when the Ignition is in the ON position?
Old Sep 20, 2006 | 09:38 AM
garyc17's Avatar
Yes I hear a tick. I just had it replaced just in case. I can hear the pump prime as well, but when I first bought the car, it primed loud. Now it primes softly.
Old Sep 20, 2006 | 09:40 AM
turbociviccoupe's Avatar
Default Re: (garyc17)
maybe pump is weakening...car still starts fine right?
Old Sep 20, 2006 | 09:51 AM
garyc17's Avatar
Yup, car starts fine. maybe once every 2 weeks it starts on the 2nd crank.
Old Sep 20, 2006 | 09:57 AM
just drive it then.
Old Sep 20, 2006 | 10:06 PM
garyc17's Avatar
Actually I am having some surging/stuttering going over uneven road surfaces. Was trying to narrow the problem down. Seems its not the fuel pump from the help I got from this thread.
Freemananana
37
Sep 23, 2015 04:32 AM
k20z1_types
Feb 12, 2010 06:30 AM
TurboKneeGrow
May 9, 2008 01:17 PM
nabin
58
Nov 10, 2007 03:24 PM
incognito E46
Feb 21, 2006 05:33 PM
