distributor moving
Old Sep 15, 2006 | 10:59 PM
6doorsentra's Avatar
Default distributor moving
i have a 99d16y8 into my 88hf crx...im using a obd1 distributor...i wired it up and it just cranks but wont turn over. plus i have no power to the fuel injectors. im using 91 si intake manifold so basicly obd0 injectors.
well when i crank the car the distributor moves like wobbles...like its pushin itself out from the motor...only two bolts are hooked up..im not getting any sparks from the cap..i think it might be the ignitor..i wont replace it yet because of the fact it moving...any reason why it would be moving when tryin to turn over?
Old Sep 15, 2006 | 11:05 PM
2poor2tune's Avatar
Default Re: distributor moving (6doorsentra)
is it wired for obd-1? the car i mean. is it?
Old Sep 15, 2006 | 11:10 PM
yeah it has p28 with ecu jumper harness..
obd1 dist..obd0 injectors because of 91 si crx
Old Sep 16, 2006 | 10:16 AM
2poor2tune's Avatar
some people put it in 180 degrees off. make sure you dident do that. ten start replacing or testeing part at autozone insadie the dizzy
Old Sep 16, 2006 | 11:11 AM
Suck my DX's Avatar
Default Re: (2poor2tune)
tighten the bolts
SikAuto
Dec 28, 2008 12:58 AM
slickrickauto
10
Aug 17, 2008 03:57 PM
p2motorsportcrx
Sep 24, 2005 06:48 PM
GReddy SI
Jan 8, 2003 12:29 AM
