NEED HELP PLEASE
Old Sep 15, 2006 | 10:05 PM
aaronfelipe's Avatar
Default NEED HELP PLEASE
I have a friend with a '88 crx si with the stock motor. Car/motor have 148*** miles(D16A6). The motor is leaking coolant fluid from the back of the motor between the alternator and the oil filter, right below the water pump. What could the problem be?
ALL help appreciated.
Thanks,
Aaron
Old Sep 16, 2006 | 12:18 AM
crxnj's Avatar
Default Re: NEED HELP PLEASE (aaronfelipe)
you say right below the waterpump? my 1st guess would be the waterpump.when's the last time it was replaced?
Old Sep 16, 2006 | 08:42 AM
Default Re: NEED HELP PLEASE (Mr.speaker)
I replaced it a couple of months ago. I took the little plastic cover that covers the top camsharft pulley and it looked dry. If it was the water pump, I think the timing belt would be wet.
Old Sep 16, 2006 | 08:43 AM
EL Vap133's Avatar
The water pump isn't near the oil filter.
Old Sep 16, 2006 | 08:44 AM
Default Re: NEED HELP PLEASE (EL Vap133)
The water pump is diagonally to the left,over the oil filter. In front of the alternator.
Old Sep 16, 2006 | 09:05 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronfelipe &raquo;</TD></TR><TR><TD CLASS="quote">The water pump is diagonally to the left,over the oil filter. In front of the alternator.</TD></TR></TABLE>
Really?
Old Sep 16, 2006 | 09:10 AM
Yes. I don't care what you are trying to prove, if you are trying to prove something. It is in between the alternator and the oil filter and it is not the water pump. We just need this car up and running.
Old Sep 16, 2006 | 09:53 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronfelipe &raquo;</TD></TR><TR><TD CLASS="quote">Yes. I don't care what you are trying to prove, if you are trying to prove something. It is in between the alternator and the oil filter and it is not the water pump. We just need this car up and running.</TD></TR></TABLE>
Actually I was not trying to prove anything, I was trying to help you out since you seem to think the water pump is next to the oil filter. I even provided you with a diagram so you could show us where it is leaking from. But sorry for trying to help.
Old Sep 16, 2006 | 10:05 AM
Nah man, don't take offense by any means. What I mean is that the water pump is right in front of the ALTERNATOR, not the oil filter.
Old Sep 16, 2006 | 12:04 PM
mahatma's Avatar
it's probably coming from the coolant pipe on the back of the block that runs between the water pump & the thermostat housing. there's a nipple on the pipe that connects to the IM i believe, check that.
i just had to fix a leak on mine after i built it, and it's a bitch to get to stuff back there. good luck
Old Sep 17, 2006 | 08:57 AM
Default Re: NEED HELP PLEASE (mahatma)
We had a buddy of mine come over and he thought it was that but said that it was dry in that area. We think it may be the waterpump. Has it even happened to any1? Bad water pump?
Old Sep 17, 2006 | 11:57 AM
It appears to be the water pump lower "weep" hole. We are going to return the old one under warranty.
Aaron
Old Sep 17, 2006 | 02:40 PM
h224thgensedan's Avatar
check the o ring on the water pipe coming from the water pump
Old Sep 18, 2006 | 07:45 PM
Default Re: (h224thgensedan)
Water was leaking thru the "Weep hole" in the water pump which was new. Thanks for the help guys.
loghead20
Dec 8, 2017 09:38 PM
KDvtec5757
10
Nov 8, 2008 06:59 PM
Damon Reeves
Feb 2, 2007 11:46 AM
average_boost
Dec 3, 2004 09:12 PM
