im have a little issue...
ok im having an issue, im not sure whats going on...
my water res. will empty it self in under 5-8 miles, an thats babying the rpms....
im leaking coolent somewhere...very small puddle besides my drivers wheel...
so far ive...
changed oil, oil pressure sending unit, oil filter, flushed coolent and i cant figure it out...
and theres a small clicking.. very very very small
is this my waterpump shot? causing fluid to leak out the weep hole, WHERE IS THE WEEP HOLE LOCATED at?
also, ill throw a check light after about 5 miles...
i need all the help i can get thanks
so far ive...
Re: im have a little issue... (average_boost)
Maybe the gasket for your water pump has a leak since you say it's coming from the driver side. I bet it's that....when was the last time you replaced your water pump?
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: im have a little issue... (CivicEJ1)
I would say its water pump all the way. Replace it and do the timing belt while your in there if it hasn't been done in a while.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Driver side = water pump.
yep.
yep.
Re: (Dimi)
Better check it and replace it or suffer serious consequences to your engine.</TD></TR></TABLE> Yeah bro, you have a serious water pump malfunction. And pouring 2 gallons of coolant in there a day will = a water pump in a few weeks.
