car iddling problem need some help!
first it take a few crank before the car turns on. but after it turn only it iddle around 2k. the big problem im concerning is when i give it some gass, the rpm decrease and then slowly die? does anyone know anything about this? i would be apreciated if you guys can share some experience
ah i have the same **** problem, it will start, and slow act like its dying and then reach normal operating status, and once i give it gas it will decrease in rpm. And when im driving under 3000 rpm its slow as *****.
My theory- Im running rich due to bad intake temperature sensor. Maybe it is the same problem for j000
check if you have any codes.. also try cleaning the throttle plate and throttle body that could be a result of carbon build up, i mean it could be alot of things but give the cheap things a whirl first
redraven_k6
Apr 19, 2010 09:07 PM
wicked013
Mar 9, 2004 03:46 AM
