Gauge Cluster/ Fuel Acting up
Old Sep 15, 2006 | 05:45 PM
JDM_Spec_SI-R's Avatar
Default Gauge Cluster/ Fuel Acting up
I HAVE BEEN HAVING SOME PROBLEMS WITH MY GAUGES/ FUEL READING. WHEN EVER I AM LOWER THAN 3/4 OF A TANK, AND PRESS THE GAS, MY FUEL METER DROPS WAY LOW AND READS AT NO FUEL. SO I HAVE TO GO BY HOW MANY MILES I HAVE? ANY LEADS ON WHAT THE PROBLEM IS? I HAVE HEARD ITS MY KNOCK SENSOR, WHATEVER THAT IS, OR MY CLUSTER ITSELF. ANY HELP???
THANKS
Old Sep 15, 2006 | 06:00 PM
TeamNextGenChris's Avatar
Default Re: Gauge Cluster/ Fuel Acting up (JDM_Spec_SI-R)
sounds like either the gauge has a dead spot in it,or the fuel level sending unit in the tank has a dead spot.
the shop manual has a resistance range for the sending unit.i'd test it first.if it tests fine,i'd say it has to be the gauge itself.you can replace the just the fuel gauge assembly in the cluster.
Chris
Old Sep 16, 2006 | 06:07 PM
Default Re: Gauge Cluster/ Fuel Acting up (TeamNextGenChris)
ok, where is the fuel level sending unit and how would i test for it? ive looked for problems by my pump and everything looks fine. then i started to think that it could be my sensor in the tank itself. my gauges, that was my first thought of replacing fist. thanks for the help!
Old Sep 16, 2006 | 08:50 PM
Syndacate's Avatar
Does it move back at all? It's possible that it's just part of Honda's crappy gas guage float system theory.
Old Sep 19, 2006 | 04:56 PM
Default Re: (Syndacate)
yeah it moves back, but slowly. the gauge will read a 1/2 tank, but i can gas it and it drops fast. it could then read empty, 1/4, or inbetween. but it slowly rises back up, if i drive slow, but even when i do drive slow, it does it too. but not as much
Old Sep 20, 2006 | 05:53 PM
:Andrew's Avatar
Default Re: (JDM_Spec_SI-R)
i would say your fuel sending unit as well. and its in your gas tank.
jasonlunaa
Nov 26, 2014 07:22 AM
B6tizzleHatch
Aug 2, 2006 07:06 AM
foam
Mar 6, 2006 10:20 PM
fubulous
Apr 22, 2004 05:56 AM
