how to remove glue on gauges?
Old Sep 15, 2006 | 05:22 PM
ac_attak's Avatar
Default how to remove glue on gauges?
I removed the aftermarket gauges that the previous owner had installed. He had them glued on, what would be the easiest way to clean up the glue off the factory gauges? Also my speedo is off so i am thinking he had the needle removed and placed it back in the wrong position, how could i correct this?
I have been searching and a guy said to place the needle on just before the stop, then lift it over the stop so i guess i'll try that out tomorrow.
Old Sep 15, 2006 | 05:27 PM
mike9571's Avatar
Default Re: how to remove glue on gauges? (ac_attak)
Any kind of solvent based degreaser will do the job. Look for it at a local autostore.
EDIT: Goo-gone is alot cheaper and you can get it at grocery stores
Old Sep 15, 2006 | 05:38 PM
ac_attak's Avatar
eah i have some goo gone here, i'll try that out in the morning. Anybody got any tips on removing my speedo needle and reinstalling it correctly?
Old Sep 15, 2006 | 05:42 PM
mike9571's Avatar
https://honda-tech.com/zerothread?id=837111
Old Sep 15, 2006 | 06:30 PM
ac_attak's Avatar
Thats perfect, exactly what i was looking for. Thanks
Old Sep 15, 2006 | 06:36 PM
jdm_bones's Avatar
Goo-Gone FTW...anything else, will damage the plastic and make it cloudy... Seen it happen, true story!
Old Sep 16, 2006 | 11:56 AM
ac_attak's Avatar
Default Re: how to remove glue on gauges? (jdm_bones)
Damn i cant get the glue off the factory gauges at all. Is there anywhere i can buy aftermarket gauges replicated after the canadian cluster?
94h22a
Apr 4, 2005 07:12 PM
nocturnaldragon
23
May 3, 2004 03:01 PM
At_oNe315
Mar 22, 2004 09:03 AM
matt7137
Jul 11, 2003 08:13 AM
95 Gizzer
Sep 10, 2002 06:16 PM
