Torque Specs on arp studs for d16z6
Old Sep 15, 2006 | 03:37 PM
LaOstha's Avatar
Default Torque Specs on arp studs for d16z6
i need torque specs for arp headstuds with moly lube on d16z6. Also if you take the distributor off and rotate the rotor will it expletive up the timing? I know it goes in one way.
Old Sep 15, 2006 | 03:54 PM
LaOstha's Avatar
Default Re: Torque Specs on arp studs for d16z6 (LaOstha)
anyone?
Old Sep 15, 2006 | 04:24 PM
b00st Junkie's Avatar
TOASTYYY!!
I have a box with the instructions at home. Ill look it up for you and post back.
Old Sep 15, 2006 | 04:52 PM
Luserkid's Avatar
Default Re: Torque Specs on arp studs for d16z6 (b00st Junkie)
65ft-lbs and for the dist. Timing is determined when the dist. goes back on, and you need a timing light to set it straight.
Old Sep 15, 2006 | 04:54 PM
Timmay's Avatar
here is what i do
start from the middle then go out
i start them all at 20 , then to 40 and tighten and loosen them a few times. that gives helps them stretch
then after i do that I do 60lbs
i start from the middle then go like this
7 3 1 6 10
9 5 2 4 8
also being that you are D-series you can do them 1 at a time.. make sure to use the arp moly lube to
Old Sep 15, 2006 | 05:07 PM
LaOstha's Avatar
Default Re: Torque Specs on arp studs for d16z6 (Timmay)
what about putting loctite on the part that goes into the block
Old Sep 15, 2006 | 05:08 PM
LaOstha's Avatar
thanks for the replies
Old Sep 15, 2006 | 05:10 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha &raquo;</TD></TR><TR><TD CLASS="quote">what about putting loctite on the part that goes into the block</TD></TR></TABLE>
<FONT SIZE="3">DO NOT DO THAT!!!!!!! </FONT>
Put some Moly lube in there.
Timmay's Avatar
no use the arp moly lube that comes with them
Old Sep 15, 2006 | 05:18 PM
LaOstha's Avatar
aight thats what i did.
Old Sep 15, 2006 | 05:24 PM
Timmay's Avatar
some people say to re tq after 50 miles or so.. but thats usually why i tighten and loosen at 40lbs a few times to give them a stretch
Old Sep 16, 2006 | 10:45 AM
LaOstha's Avatar
wahts the firing order for the dizzy?i searched and found
however it wont start with it like that i switched it and put it at
and it would start but runs rough
jcrredrex2012
Jan 4, 2013 10:47 PM
swirve1
Feb 4, 2010 08:43 PM
JScott3d
Mar 14, 2008 06:17 AM
EF9ZC
May 3, 2006 11:07 AM
