BAD NEWS MOTOR MOUNT BROKE OIL ALL OVER
today i was driving slammed into second on the freeyway to pass atruck and now i 3
have oil all over and a dent in my hood anybody now how mucha driverside motor mount will cost me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">today i was driving slammed into second on the freeyway to pass atruck and now i 3
have oil all over and a dent in my hood anybody now how mucha driverside motor mount will cost me</TD></TR></TABLE>
driverside mount should cost about $50. depends where you go, but i would be more concern about the oil than the mount.
so your motor mount broke off and hit your hood? or your motor broke off the welded mount bracket and motor bounced and hit your hood? how can that be?! show pics....not sure what you want...hahahha
y u laughing i guess the rubber seal broke and now all the fluid is coming out my mistake not oil fluid it broke the rubber seal and now the screw that holds the throttle canble on top of the vlve cover hit the hood as it went up i put the e brake on and put it in first and threw the the windshield i can literealy see the motor moving up
The mounts are fluid filled, so I assume the "oil" he's talking about came from the ruptured rubber isolator on the driver's side and the engine hit the hood when it torqued free of the mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5g »</TD></TR><TR><TD CLASS="quote">are you positive the mounts have fluid in them...</TD></TR></TABLE>
If I wasn't I wouldn't have said so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 »</TD></TR><TR><TD CLASS="quote">Yes the mount has fluid in it. Honda made 3 driverside mounts during the EG model cars I do believe. </TD></TR></TABLE>
only the 96+ civic have them.
The exact thing happened to me. I ripped my driverside mount to shreads and all of the oil from inside it went everywere. It's defiantly the motor mount. I believe a replacement one is 90$ from honda.
http://cgi.ebay.com/ebaymotors...QrdZ1
i've bought several mounts from these guys.so far they're as good as OEM.
BTW-if you're driving the car that hard,you may consider buying the inserts for the two lower front and rear mounts.they work well to limit movement and take some of the stress off that fragile top mount.they're also much cheaper than buying another new mount.
oh,TURN OFF THE CAPS LOCK ON THE TITLE!!
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">only the 96+ civic have them.</TD></TR></TABLE>
No, most every motor mount Honda has is fluid filled. It's filled with antifreeze and over time it will start to rust and that rusty colored fluid is what comes out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 »</TD></TR><TR><TD CLASS="quote">alrite thank you everybody for ur help and where can i get these inserts from and where do they go do i make them my self </TD></TR></TABLE>
We sell energy suspension motor mount inserts, just let us know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">
No, most every motor mount Honda has is fluid filled. It's filled with antifreeze and over time it will start to rust and that rusty colored fluid is what comes out.</TD></TR></TABLE>
you sure about that? I know the 96+ civics have it and I know for damn sure that EG's don't. I think you are mistaken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_fan »</TD></TR><TR><TD CLASS="quote">you sure about that? I know the 96+ civics have it and I know for damn sure that EG's don't. I think you are mistaken.</TD></TR></TABLE>
I've broke open 2 of them on a EG and have seen numerous other threads with people having the same problem and fluid all over the bay. A few 92-93's with the 2 bolt angle mount have them and most all with the 3 bolt straight mount are fluid filled. Same way with the Integras.
96delsol123
Apr 7, 2013 06:17 PM
KiDSoL
Jun 13, 2003 03:45 AM
