whats the best spark plugs and leads??
my civics a little hesitant some time when you put your foot down on the go pedal. i think it may have some benifit from a nice new set of plugs and leads.
what would you recommend, are there some performance leads and plugs that are particularly recommended for these civics (b16a)
cheers!
cheers!
i highly doubt it's the plugs, might want to look further into the problem. but ngk's are most likely the best. i have ngk v-power on my b16a, and they work great. i know the iridium plugs are alot better, but i have heard of the tips breaking off and causing internal engine damage.
NGK copper plugs.no performance advantage to the iridiums,just a longer life.but for the price of them,you could buy several sets of the standard $1.50 each plugs and change them more often.
for wires,stock or NGK.period.again,no performance advantage to other aftermarket wires,just shitty quality and higher prices.
Chris
Chris
when is it hesitant? my daily driven accord is now hesitant even at stant still..when i press the gas pedal to 1000 rpm its steady as before..but i changed the spark plugs, distributor cap and it got a little better..but still hesitates..lmk if u find out what ur problem is.
