Identify these sensors please
i have a crx with a b16 from a 99si running a 0bd2 p73 ecu, using a obd0 to obd2 jumper harness. Car runs perfect and throws NO codes, question is why are these sensors unplugged and its not throwing codes. Also can you give me the names of each one.
1 is your vtec oil press sensor .. you must have a jdm ecu if vtec pops without it (or chipped)
2 is reverse lights
3 is evap purge which you don't need
2 is reverse lights
i know fo sur ejdm type-r's dont require it but i guess obd0 doesn't require it either
it's a sensor that won't let vtec pop if oil pressure is too low
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ne3ek »</TD></TR><TR><TD CLASS="quote">1 is your vtec oil press sensor .. you must have a jdm ecu if vtec pops without it (or chipped)
2 is reverse lights
3 is evap purge which you don't need</TD></TR></TABLE>
2 is reverse lights
That IS a JDM ecu like I told you in your other thread.
Check here to decode the label.--->http://www.pgmfi.org/twiki/bin...ecode
Stephdavis18
Jan 20, 2007 11:55 PM
nutar
Jun 5, 2006 09:49 PM
