Polishing my Manifold - Again...
When I bought my manifold, ramhorn style it was super shiny. I know SS turns which is normal, however it has dulled a good bit...is there a way to shine it back up?
Thanks.
Thanks.
You can probably just use some polishing wadding. Brasso makes it and so does eagle one and some other companies as wheel polish. I like the wadding stuff better than they liquid. Once youve gone over it a lot, you can get a soft cloth and buff it back to being nice and shiny.
And if the surface is too rough or dirty to come clean easily with NeverDull or the like, you can use a scotch brite pad and some WD-40 first, then polish after.
^And if the surface is too rough or dirty to come clean easily with NeverDull or the like, you can use a scotch brite pad and some WD-40 first, then polish after.
