im i anywhere near my goal..
hers my set up....
buddyclub spec 3 cams,
buddyclub cam gears,
buddyclub spec3 exhaust
dc-sports de-cat
spoon tb 65mm
spoon headgasket
spoon 35mm rad
spoon thermostat
spoon fan/switch
arc air box and filter
5zigen 4-2-1 haeder
h22 injectors
b18c fuel pump
b18c oil pump
trust oil cooler
apex power fc
exedy stage 2 clutch
orc flywheel
ats 4.9 final drive
i havnt got it tuned are dynoed yet but im looking for over 200bhp what ye's think
BTW i run my car on 100octane if that helps
dc-sports de-cat
spoon tb 65mm
spoon headgasket
spoon 35mm rad
spoon thermostat
spoon fan/switch
5zigen 4-2-1 haeder
h22 injectors
b18c fuel pump
b18c oil pump
trust oil cooler
apex power fc
orc flywheel
ats 4.9 final drive
i like the ats 4.9 fd, but what is it?
full gsr ? ls/vtec ? type r? or b16?
what transmission? or is this all just a dream....?
Modified by dragonz04 at 10:54 PM 9/15/2006
when I was asking what is it? I was referring to the motor. I do know about the ats 4.9 fd because I have that in my ITR transmission along with the ATS 3.077 longer 1st gear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonz04 »</TD></TR><TR><TD CLASS="quote">when I was asking what is it? I was referring to the motor. I do know about the ats 4.9 fd because I have that in my ITR transmission along with the ATS 3.077 longer 1st gear</TD></TR></TABLE>
I belive you mean shorter first gear.
I swear you create more threads than anyone on Honda Tech. Just build your ****, and have it tuned. Done. I don't mean to be rude but seriously:
In less than 4 months...
» Search Results (under your screen name)
Your search returned 32 results.
......have you ever tried searching before you make a thread?
the ATS first gear is LONGER. why would anyone put in a shorter first gear?
and if you really had all these parts, why not show us a dynograph and tell us how it went.
thats what im working on im just waithing on my obd2b to obd2a ecu harness then i can get it all mapped as soon as i get the dyno graph i will post it up.
