Slight Ticking Noise from the Engine.. what does that mean?
Old Sep 15, 2006 | 07:39 AM
yzprelude's Avatar
Default Slight Ticking Noise from the Engine.. what does that mean?
I took my 97 prelude to the mechanic for an oil change and he claims that there is a slight ticking noise from the engine. what does that mean?
Old Sep 15, 2006 | 07:58 AM
MadCityLude
Guest
Posts: n/a
Default Re: Slight Ticking Noise from the Engine.. what does that mean? (yzprelude)
Generally means you need a valve job done. Possibly adjustments or maybe more.
Old Sep 15, 2006 | 08:21 AM
Kagelude's Avatar
Default Re: Slight Ticking Noise from the Engine.. what does that mean? (MadCityLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">Generally means you need a valve job done. Possibly adjustments or maybe more.</TD></TR></TABLE>
X2 , honda dealer can do it for 90 -100$ and free inspection fo the car (which is probably factored into the price, but hey..)
Old Sep 15, 2006 | 08:29 AM
yzprelude's Avatar
what causes valves to go bad @ 108,000 miles?
Old Sep 15, 2006 | 08:39 AM
Kagelude's Avatar
Default Re: Slight Ticking Noise from the Engine.. what does that mean? (Kagelude)
that doesn't mean that hey have gone bad.. i just means that they are out of spec.. for a car with 108,000 miles it should have gotten adjusted long ago.. i'm not sure what the numbers are but for hondas its just a matter of time before one is needed. (part of maintenance)
Old Sep 15, 2006 | 08:46 AM
paulab's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kagelude &raquo;</TD></TR><TR><TD CLASS="quote">that doesn't mean that hey have gone bad.. i just means that they are out of spec.. for a car with 108,000 miles it should have gotten adjusted long ago.. i'm not sure what the numbers are but for hondas its just a matter of time before one is needed. (part of maintenance)</TD></TR></TABLE>
What's involved in adjusting them and what tools are needed? Is this something best left to the dealer?
Old Sep 15, 2006 | 08:57 AM
Lewdin' Incognito's Avatar
Default Re: Slight Ticking Noise from the Engine.. what does that mean? (paulab)
If you have to ask - then yes. It's really not that hard, but if you screw it up it could seriously hurt your car and wallet. I think a dealer charges about an hour, and they have all the tools/gauges.
Old Sep 15, 2006 | 09:24 AM
paulab's Avatar
Default Re: Slight Ticking Noise from the Engine.. what does that mean? (Lewdin' Incognito)
I am learning more and more how to do the maintenance on my car and love the opportunity to learn new things each time something needs some work (how else will I learn, right?). I have time scheduled at an upcoming lift session so I may attempt it then in the presence of people that can guide me so I don't screw anything up.
Old Sep 15, 2006 | 10:26 AM
yzprelude's Avatar
So am I safe to drive it for a while do I have to get it checked right away? I just want to drive the car knowing that it's not going to blow the engine a mile down the road.
Old Sep 15, 2006 | 10:28 AM
l2yanE's Avatar
Default Re: (yzprelude)
im to lazy to search it right now but there is a writup about adjusting you valves- check it out and you can get a good idea if you wanna tackle it yourself
Old Sep 15, 2006 | 10:34 AM
daoshao's Avatar
need a valve adjustment....get a helms manual or haynes, chilton etc.
Old Sep 15, 2006 | 10:49 AM
prelude_h22vtec's Avatar
i'll do it for $20 ha jk, learn how to do it. it's really simple and will save you money.
Old Sep 15, 2006 | 11:20 AM
Kagelude's Avatar
Default Re: (l2yanE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l2yanE &raquo;</TD></TR><TR><TD CLASS="quote">im to lazy to search it right now but there is a writup about adjusting you valves- check it out and you can get a good idea if you wanna tackle it yourself
X2
i over"came" my laziness
https://honda-tech.com/zerothread?id=618786
thats the link for the DIY on the valve adjustment
Old Sep 15, 2006 | 12:02 PM
paulab's Avatar
Default Re: (Kagelude)
Thanks for the link. I may attempt it at the lift session tomorrow but will most likely wait until the next one.
Old Sep 18, 2006 | 10:31 PM
yzprelude's Avatar
I started it up today and it has the ticking that is comming from the valve cover. It doesn't tick as loud when it first starts up, but then it gets to be louder when the car warms up.
Old Sep 19, 2006 | 09:33 AM
Slvrwnd's Avatar
This might also help with the process
http://www.amazon.com/Alltrade...&s=hi
its the tool if you don't want to fab one up or buy the snap-on one. much cheaper i might add $12 compare to $40
gusstuff
Honda Civic (2006 - 2015)
12
Jun 8, 2014 12:42 PM
cleartouch33
Dec 15, 2006 09:18 AM
ilikeric3
Sep 8, 2006 08:32 PM
marfer
Acura TL, RL & ZDX
Nov 29, 2003 01:09 PM
BryanS
Sep 25, 2001 10:46 AM
