ls swap wiring help.
Old Sep 15, 2006 | 06:38 AM
skoodles2k6's Avatar
Default ls swap wiring help.
I've ben lookin aruond doing some reading and well im down to the point of wiring my swap. i got a 91 ef hatch belive the old motor was dpi and i need to convert to mpi. and im sure its going from obd0 - obd1 my motor ls is a 93 is there a conversion harness or some wehre that shows where i can splice my engine harness to my plugs comming out on the firewall cause i havent looked l8ly but i belive the plugs are different. and im probably gonna have to get a jumper harness too for the ecu. if anyone could shed some light for me id appreciate it.
Old Sep 15, 2006 | 08:00 AM
Rywire's Avatar
Default Re: ls swap wiring help. (skoodles2k6)
You need to do a dpfi to mpfi conversion as well as convert to obd1 (if you plan on using the 93 dizzy and ecu). my site has info for u
DA john
15
Mar 23, 2013 12:45 PM
Homotor
Oct 18, 2010 08:37 AM
HtC_SiR
May 26, 2004 12:11 PM
apron8
Aug 14, 2003 03:21 PM
rwcdrums
Dec 19, 2002 01:15 PM
