car shaking when I get on it
Ok guys I have a 2000 si with a gsr swap and some other goodies.....well I'm not goin to lie.....I got some bald *** tires on my car and they are probabaly not weighted correctly.
My question is could the condition of my tires be the reason why when I get on it the car shakes a bit....never did this b4.....all suggestions are welcomed.....
Thanks in advance guys!!!!!!!!!!!!
Make sure your axles are seated fully into the transmission. But also get those tires replaced and balanced. If one of the axles are even slightly out of the tranny, it will cause mild to violent shaking upon acceleration only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomO »</TD></TR><TR><TD CLASS="quote">Make sure your axles are seated fully into the transmission. If one of the axles are even slightly out of the tranny, it will cause mild to violent shaking upon acceleration only.</TD></TR></TABLE>
I am experiencing this very thing now....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ctrb »</TD></TR><TR><TD CLASS="quote">I would defenitely change the tires, balance.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Meow.</TD></TR></TABLE>
Uh....huh?
Uh....huh?
get 'em changed and balance but one thing first:
If you floor it in first, does is shake? Shakes do to improper balancing tend to take effect around 50mph. If it's shaking just as bad when you're doign 15 with the pedal down, it may not be that (but then again it could still be your wheel alignment). I'd recommend new tires, balance, and 4 wheel alignment. See where you are from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">ever see spongebob Gary?</TD></TR></TABLE>
Just about every day.
(I have a 4 and a 2 year old boys)
komat
Sep 3, 2010 07:14 AM
