Crazy Idol Problems
Old Sep 15, 2006 | 03:16 AM
hondamad's Avatar
Default Crazy Idol Problems
I have a '00' Honda Civic EK Hatch and when I start it up it starts a crazy rev. High and low high and low all on its own . I dont know what RPM it revs up to tho because I dont have a Tacho. Anyone know what may be the cause of this and what I will need to do to fix it? Any help would be good.
Old Sep 15, 2006 | 04:11 AM
instrument's Avatar
i thought maybe you had a thing for taylor hicks.
Old Sep 15, 2006 | 04:42 AM
92ehatch's Avatar
Default Re: Crazy Idol Problems (hondamad)
check all your vaccuum lines to make sure they are connceted, not dry rotted or cracking, then clean your IACV.
if none of those work, check your PCV valve, if it fails it can cause that, and its very cheap to fix.
also wanna lookat the FITV
Old Sep 15, 2006 | 04:51 AM
sohcEJ8's Avatar
Default Re: (instrument)
lol
Old Sep 15, 2006 | 05:22 AM
TorquelessB16's Avatar
He had Idol problems too...
But if you mean IDLE, you should take the car to a mechanic because there are a million things that could be wrong. It took my months to figure out why mine did that exact same thing. Turned out to be the o2 sensor on the TB.
Old Sep 15, 2006 | 06:08 AM
w0ng_sta's Avatar
Default Re: Crazy Idol Problems (TorquelessB16)
any codes? if yes then find out which ones, if not, most likely vaccum leak, bubble in coolant, or possibly iac but doubtful if no code.
feel around make sure no leaks, if theres a bubble then on a cold start open your radiator cap and let it run till the bubbles stop, add coolant if neccessary.
Old Sep 15, 2006 | 07:58 AM
-Gary-'s Avatar
Default Re: Crazy Idol Problems (w0ng_sta)
Idle Air Control Valve.
Do a serach for this and you will find the resolution to your issue...
Old Sep 15, 2006 | 09:38 PM
jdeemseerx's Avatar
the o2 sensor on the throttle body eh? i really hope you were heavily inebriated or on some kind of non-OTC drug when you posted that garbage. no wonder why it took you months.. you were probably looking for the TPS on the exhaust manifold.. im not trying to bully you, nor do i want you to post a comeback to what i've said, im simply just trying to point out the fact that you sir should not be tryin to point someone in the right direction when you clearly dont know what your talking about. To the OP, search on how to tighten the wax screw inside of the FITV, do it, and afterwards bleed the coolant system.. 99% chance this will solve your problem
Old Sep 15, 2006 | 11:16 PM
hondamad's Avatar
Cheers everyone. Ill try the stuff suggested and will see if it all go's ok.
Old Sep 20, 2006 | 12:09 AM
hondamad's Avatar
Havent found anything yet... Though if its a vaccum leak, where are the common places for it to leak from so i know EXACTLY where to look.
Old Sep 20, 2006 | 02:21 AM
Cuda70's Avatar
Default Re: Crazy Idol Problems (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">the o2 sensor on the throttle body eh? i really hope you were heavily inebriated or on some kind of non-OTC drug when you posted that garbage. no wonder why it took you months.. you were probably looking for the TPS on the exhaust manifold.. im not trying to bully you, nor do i want you to post a comeback to what i've said, im simply just trying to point out the fact that you sir should not be tryin to point someone in the right direction when you clearly dont know what your talking about. To the OP, search on how to tighten the wax screw inside of the FITV, do it, and afterwards bleed the coolant system.. 99% chance this will solve your problem </TD></TR></TABLE>
Well, an O2 on the throttle body would give you a bad idol... (Idol purposefully placed to add to the confusion)
OP, you will need to check all the hoses first. You can disconnect each, one by one and plug the hole with your thumb (Or finger which ever you like best) If your idle stabilizes, then you found your problem. If it does not, your next step will be the ICAV. If that does not correct the problem, you might want to substitute your O2 with a known good one to see if it is working properly.
That is the order I would do it in....
And please, don't try to screw an O2 into your throttle body.
Old Sep 20, 2006 | 05:05 AM
jmayhew's Avatar
Default Re: Crazy Idol Problems (Cuda70)
also check your grounds....i had a bad ground conection that was cause it to idle funny & made it hard to start
Old Sep 21, 2006 | 07:09 AM
55greenEK's Avatar
i also have a question my car idols at like 300 rpm is it normal to i dol that low. the only thing is that my timing is advanced does that effect the idol any. pm me please
Daproject711
Feb 24, 2011 05:01 AM
the.hamburglar
May 10, 2007 08:46 PM
blinger
Nov 30, 2006 10:42 AM
redpeppers
Jul 26, 2005 05:10 AM
balldipperMP
Dec 10, 2002 07:43 AM
