What rotor should I replace my stock ones with??
Old Apr 29, 2002 | 08:37 PM
Wet Nudl's Avatar
New User
Default What rotor should I replace my stock ones with??
I was told by a friend I can just get rotors from Autozone and they are a good OEM replacement. I don't need anything fancy or hardcore but just a straight replacement. My current rotors are warped so I want to swap them out. Should I replace all four or just the two front?
Also, what's the Autozone part number for our rotors?
[Modified by typeRP, 9:38 PM 4/29/2002]
Old Apr 29, 2002 | 08:39 PM
B2FiNiTY's Avatar
Default Re: What rotor should I replace my stock ones with?? (typeRP)
Brembo or the bling bling spoons.
Old Apr 29, 2002 | 08:41 PM
Wet Nudl's Avatar
New User
Default Re: What rotor should I replace my stock ones with?? ( B2FiNiTY)
Sure B2, I have a TypeRP donation center setup just for you.. Come on over my friend..
Old Apr 29, 2002 | 08:42 PM
Scorpaznatica's Avatar
New User
The "bling bling" comes from the 2 parallel slots right?
Old Apr 29, 2002 | 08:44 PM
B2FiNiTY's Avatar
Default Re: What rotor should I replace my stock ones with?? (spooGEN)
Yup. Looks fast.
RP - You mean the SD fund? heh.
Old Apr 29, 2002 | 08:45 PM
Rob :190:'s Avatar
the autozone rotors are for a 95 Legend I believe. Talk to willard about that one though, i dont know the specifics, but would like to
Toda Party's Avatar
brembo OE replacements are pretty cheap
i got 2 front rotors from collettimotorsports for 101 shipped...shipping was like 35 bucks, damn heavy *** rotors
Old Apr 29, 2002 | 08:46 PM
Wet Nudl's Avatar
New User
Ok you PWs..
And B2, the RP foundation uses its money wisely and meticulously.. I like to pick and choose and never stick to just one.
Old Apr 29, 2002 | 08:52 PM
Rory Breaker's Avatar
Unless you want to spend the big bux...
Brembo blanks or Powerslot slotted are
Old Apr 29, 2002 | 08:53 PM
B2FiNiTY's Avatar
I say just get the brembos.
Old Apr 29, 2002 | 09:04 PM
nsxtcjr's Avatar
New User
Assuming the warping is in front (a likely assumption), just replace the front ones.
Old Apr 29, 2002 | 09:54 PM
Wet Nudl's Avatar
New User
Default Re: What rotor should I replace my stock ones with?? (nsxtcjr)
Not sure how I can tell if the rears are warped too.. But the front definitely has to go.
Old Apr 29, 2002 | 11:19 PM
tjtruong's Avatar
New User
just change the fronts, and try to feel for the rear under braking for pulsation.. other than that, my only bet would be to use a dial indicator for the rears and measure it. But in most cases the fronts should be the ones that need changing or machining.
tj
Old Apr 29, 2002 | 11:29 PM
Wet Nudl's Avatar
New User
Default Re: What rotor should I replace my stock ones with?? (tjtruong)
Thanks TJ.. Or I'll just go steal the rear rotors from Dennis's while he's in school. hahaha
Old Apr 29, 2002 | 11:45 PM
ITRbroham's Avatar
shit post warrior
What about Powerslot rotors?
Old Apr 30, 2002 | 12:36 AM
B2FiNiTY's Avatar
Watch it...TJ will get his dog and send it after you!
Alexander
Oct 5, 2002 12:25 PM
magic hat #9
Sep 18, 2002 01:22 PM
TypeR 599
Jul 27, 2002 12:23 PM
IntegraGSR23
Jan 16, 2002 04:45 PM
ActiveAero
Nov 14, 2001 05:42 PM
