Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Best and Cheapest Camber kits ( front/rear)
Old Sep 14, 2006 | 09:36 PM
Vantage's Avatar
Default Best and Cheapest Camber kits ( front/rear)
Hey guys. So heres the story...
Kinda had a bad day, started off with a flat tire. As i took the tire off, i noticed i had A LOOOTTTT of camber wear. I was told that using my H&R sports kept me in the stock camber "zone" and that i shouldnt expect excess camber wear ( although of course there would be more than stock)
But my tires are maybe 6 months old and already the inside is down to 30-40%, while the outside remains at 90%+.
So im gunna get the tires flipped, but i need to prevent this from happening in the future, as I cant shell out big $$$ on tires every year.
What is the best and cheapest camber kits around.
I know "best" and "cheapest" never should be in the same sentence, but seriously, if ur OBX camber kit is working 100% flawlessly, I want to know about it.
So far ive got the Ive heard the ingalls from kit is good and VERY cheap. while the SPC rear kit is also very good, and relatively cheap.
Is this a good combo? or can i just go full ignalls?
I havent found a place that sells SPC locally, and im VERY against ebay ( bad experience) so id prefer to deal with my local shop if at all possible.
Please list and and all Good cheap camber kits out there.
Old Sep 14, 2006 | 09:39 PM
Vantage's Avatar
Also,
Are Civic Si and RSX camber kits the same as the Em2 chassis?
Do omnipower make kits that work on our car?( i can get them for cheap)
Old Sep 14, 2006 | 10:15 PM
susuking's Avatar
i think u can use the civic si, since it's transferable with the EM chassis. correct me if i'm wrong
Old Sep 14, 2006 | 10:19 PM
tak1civic's Avatar
UR RIGHT YOU CAN USE THE RSX ONE TOO...................
Old Sep 15, 2006 | 06:08 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Best and Cheapest Camber kits (B18a_CRX)
You sure that's not toe wear instead?
You won't see camber wear unless you have a significant amount...even then it's debatable if your other specs are normal.
The only camber kit you'd ever need os for the rear. The front will stay in spec no matter how much you lower it...that's why I think you have other issues going on.
Old Sep 15, 2006 | 06:18 AM
fventura03's Avatar
ep3/dc5/em2 are all the same camber kits, use whichever.
i've had ingalls, pretty good. sold it and got spc, after about a year it has completely rusted over, and its hard to adjust without force.
but whichever you get, it'll do the job right and work the same. i say get the camber kit, and get an alignment right after.
Old Sep 15, 2006 | 07:16 AM
Vantage's Avatar
Will toe cause wear ONLY on the inside of the tire?
Old Sep 15, 2006 | 12:48 PM
Todd00's Avatar
Default Re: (B18a_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Will toe cause wear ONLY on the inside of the tire?</TD></TR></TABLE>
Toe issues + camber will cause that. Camber by itself is usually not a problem.
Old Nov 5, 2008 | 06:43 PM
batac_boy's Avatar
Default Re: (Todd00)
Have anyone of you guys tried or have Skunk2 rear camber kits? cause that's what im going to put in my EM2 and for the front SPC?
Old Nov 5, 2008 | 09:32 PM
SHG_James's Avatar
Default Re: (batac_boy)
im running camber plates in the front and t1r camber arms in the rear
t1r is reasonably priced ($150) and the entire arm is made of aircraft aluminum unlike skunk2 which is a mix of aluminum/steel and spc is just steel
Old Nov 6, 2008 | 02:50 PM
jdm em2's Avatar
My opinion is go with some K-sports i dont no how much u think alot is but 110$ for a rear camber kit they do a great job.. !
Old Nov 6, 2008 | 05:43 PM
SHG_James's Avatar
Default Re: (jdm em2)
my spc camber kit is forsale. 60shipped, 25k on them. replaced them with t1r's. im still using the spc until my new ones come in which is around next week wednesday.
Old Nov 8, 2008 | 02:23 AM
homelessEm2's Avatar
Default Re: (jamescardenas07)
well i have had three different camber kits...i have found that 1: more $$$ dont mean better kit 2: get polyurethane bushings when u go searchin for one 3: depends on how low ur gonna go
i had a ingalls one and demolished it in 3 months bought a SPC one and the same thing happened in 4 months. the bushings jus blew out of them. now i have Ksport one with poly bushings...im hoping that this one can handle the extreme angle and duty that have a low car puts on the camber arm.
my car obviously is an "extreme" case that calls for the camber arm/kit to take a huge amount of pressure considering the angle that the arm is on and the stiffness of my suspension.
i hope this helps out a lil bit.
also i bought my Ksport from ebay, $108 shipped. you will have a better ebay experience if you deal with a store rather than an individual seller. i called ksport to ensure that the seller i was dealing with was authorized dealer and everything ahead of time.
MyIntegra
Apr 12, 2010 01:26 PM
turbotime
Jul 24, 2006 06:41 AM
Spence
Mar 4, 2004 08:55 PM
CivicSwapper
Dec 11, 2003 06:53 AM
b18C1_liLkyLe
Dec 31, 2002 04:06 PM
