what hydraulic press to use with our trannies
i'm not a honda guy but i've teared honda trannies before, i'm a mitsu guy, regardless i'd imagine it beeing the same. my question is what hydraulic press do you guys use to separate the gears from the shafts.. ton wise is my question? 12 ton be enough? or does it have to be 25 or higher? i use to work at a dealership and i cant remember what the capacity of the one at work was..
mainshaft shouldnt need a press or anything.
countershaft:
1) Loosen the nut and remove the washer
2) Replace the nut with 3-4 threads
3) take a piece of wood, place it on the floor. proceed to tap the nut end HARD on the wood. (this will break the 2 upper bearings free.)
4) Remove them
5) if the gears are still stuck, repeat step 3 and voila.
countershaft:
4) Remove them
You don't need a presse. Just got to sears and get a gear puller works fine. Dturbocivic just took my tranny all apart tonight with my gear puller.
No press needed as described above...unless its a K series...then get a good one!
We broke two small presses already before we got a 20 Ton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">You don't need a presse. Just got to sears and get a gear puller works fine. Dturbocivic just took my tranny all apart tonight with my gear puller. </TD></TR></TABLE>Do you have a pic of that puller by any chance? or maybe a part #. i'd like to get one. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-SPEC 1 »</TD></TR><TR><TD CLASS="quote">Do you have a pic of that puller by any chance? or maybe a part #. i'd like to get one. thanks.</TD></TR></TABLE>
I can take a pic for you and email it to you. I got it at sears hardware. It was like 39.99
http://www.sears.com/sr/javasr...e=Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
http://www.sears.com/sr/javasr...e=Yes</TD></TR></TABLE>
Thanks a lot. And Chad, return yours and get ur $10 refund. lol
Thanks a lot. And Chad, return yours and get ur $10 refund. lol</TD></TR></TABLE>
I just might have to.
well just for an update peeps. i got a tranny jack adapter for my floor jack, 20 bucks hehehehe so lazy.... 20 ton floor press, 160 bucks...... and this really nice kit from OTC part num. 4518 for 70 bucks....
pic of the otc kit
Eddie Rosado
pic of the otc kit
Eddie Rosado
