wicked trunk leak!
My 91 sedan's trunk is full of water!
Where is this leaking from? It was 100% dry until it started pouring rain and now its half filled with water in the tire well!
I'm thinking its like my crx where the water was coming in from the tail light gaskets.
anyone?
anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Tail lights is my quess as well, is there anywhere reasonably priced to buy these gaskets or are the dealer prices alright?</TD></TR></TABLE>
Dealer prices are allright, I got mine with my discount and I don't remember exactly how much they were but it wasent too bad.
Check above the tail lights. there should be three or four circular weld spots (well, my car has them). on one side, a few of them are beginning to rust through, and I've seen water coming from them.
yea i think it is the tail light i had the same prob except it wasent raining i was washing my car an i got water inside i jus never took time to figure it out
I checked out my car today. Tailight gaskets for sure as I can see a steady stream of water coming from the tail light area.
My car doesn't have a lot of rust so I doubt that its rusted through.
another option is diy tailight gaskets. visit a specialty hose store and get a 1x2 sheet of 1/8" neoprene gasket material. Use the old gaskets a template and mark all the holes with a sharpie.
cut out all the holes with a utility knife. Lay the gasket over the tailight and make a "x" shaped cut over the threads. install tailight and gasket on car and tighten the bolts handtight. you'll need a 3/8 copper coupling and hammer for the next part. Remove the tailights and it's obvious where you need to punch holes. The gasket material costs $5 and you'll have enough to make three sets
