buy another longblock or rebuild h23a1
Old Sep 14, 2006 | 07:57 PM
LudeJdm's Avatar
Default buy another longblock or rebuild h23a1
planning to go turbo with my h23a1...it has a lot of miles right now and has a oil leak...now should i rebuild the motor that i have now or pick up another cheap longblock...
Old Sep 14, 2006 | 08:05 PM
sivikvtec's Avatar
Default Re: buy another longblock or rebuild h23a1 (94_SI_lude)
what about an f20b?
Old Sep 14, 2006 | 08:16 PM
LudeJdm's Avatar
Default Re: buy another longblock or rebuild h23a1 (sivikvtec)
im tryn to stay obd1
Old Sep 14, 2006 | 08:21 PM
MadCityLude
Guest
Posts: n/a
Buy my H22a you were talkin bout last night!
Old Sep 14, 2006 | 08:22 PM
MadCityLude
Guest
Posts: n/a
Oh thats right never mind it sold
Now I can get my Hybrid done soon
Old Sep 14, 2006 | 08:42 PM
AndyD's Avatar
My suggestion is either a stock F22 Accord engine with low boost, or take the H23 head off your current engine and mate it to an F22 or F23 bottomend, upgrade the rings, and boost it some more.
Either way, use an F series bottomend.
Old Sep 14, 2006 | 08:48 PM
MadCityLude
Guest
Posts: n/a
Default Re: buy another longblock or rebuild h23a1 (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">My suggestion is either a stock F22 Accord engine with low boost, or take the H23 head off your current engine and mate it to an F22 or F23 bottomend, upgrade the rings, and boost it some more.
Either way, use an F series bottomend.</TD></TR></TABLE>
Thats what I am doing - option 1 with an H23 head.
Old Sep 14, 2006 | 09:42 PM
LudeJdm's Avatar
Default Re: buy another longblock or rebuild h23a1 (MadCityLude)
should i buy another low mileage h23a1 longblock or rebuild the one i have now?
Old Sep 14, 2006 | 09:52 PM
MadCityLude
Guest
Posts: n/a
Neither
Buy an F22 or F23 bottom end and use your head
Or buy an F22b JDM DOHC longblock off ebay for $500.
Sell yours.
Old Sep 14, 2006 | 10:32 PM
LudeJdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">Neither
Sell yours.</TD></TR></TABLE>
if i do pick up a f22b jdm dohc longblock what tranny do i use and what ecu??
Old Sep 14, 2006 | 10:33 PM
MadCityLude
Guest
Posts: n/a
The JDM ecu that comes with it or your H23 will also work. Use your H23 tranny.
Old Sep 14, 2006 | 10:41 PM
LudeJdm's Avatar
would all my h23a1 parts or most of them fit on the f22b?? or would i have to buy some other parts?? please list some parts i would need so i can go get them soon...
Old Sep 14, 2006 | 10:44 PM
MadCityLude
Guest
Posts: n/a
Pretty much all the parts your would need can come off your H23a
Just buy things like water pump, seals, gaskets, fluids, clutch/flywheel, belts, plugs, wires, filters (gas/air), etc.etc...
Old Sep 14, 2006 | 10:48 PM
LudeJdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">Pretty much all the parts your would need can come off your H23a
Just buy things like water pump, seals, gaskets, fluids, clutch/flywheel, belts, plugs, wires, filters (gas/air), etc.etc...</TD></TR></TABLE>
what parts are needed from a f22b??
Old Sep 14, 2006 | 10:52 PM
MadCityLude
Guest
Posts: n/a
What? Use as many F22b parts as possible. You just may need to use your sensors and stuff. I am not real sure.
I am pretty sure all the parts you buy will be for the H23 though. They are very similar.
There is a few threads here on HT about that engine if you search you can find some good info.
Old Sep 15, 2006 | 05:08 AM
AnthonyG2003
Guest
Posts: n/a
if you wanted a cheap lower mileage h23 i think M2B4 has one that he just picked up...PM him
thatonekid206
Jan 17, 2008 03:19 AM
aws140
Apr 26, 2005 07:11 AM
SIC742
Aug 13, 2004 08:54 AM
SuperShale
Feb 3, 2004 09:27 PM
