JDM D15B Swap List.
1. JDM D15B/CX trans.
2. P28 ECU
3. EX/Si Harness
4. Motor mounts(CX)
5. Linkage(CX)
6. axles(CX)
7. D16Z6 Distributer
8. ACT Clutch
9. OEM Flywheel
Does this look right or am i missing something?
Also.
My car got broken into before i annihilated the motor, and the ****** who did it took apart my steering column/ ignition. Ill post picks when im done with my swap, im going to need help putting it back together.
2. P28 ECU
3. EX/Si Harness
4. Motor mounts(CX)
5. Linkage(CX)
6. axles(CX)
8. ACT Clutch
9. OEM Flywheel
Also.
you should get the ex/si or y8 transmission
timing, p/s, a/c and alternator belt
water pump
might think about swaping the intake mani and the exhaust mani
water pump
pinks11
Dec 9, 2008 04:30 PM
FUP23
Feb 8, 2002 08:34 AM
