rh drive swap
yo guys im about ready to buy a front clip that is an h22 and manual that is rh drive. Will it be a direct swap? my car is an h23 and its automatic if that makes any difference. I know this is very vague but any help would be greatful.
I dont know exactly what it would consist of, but i can almost guarantee you that its gonna be a bit of work. Clutch master cylinder, brake booster, fuel lines, fuel rail, fuel filter..etc will likely need to be moved. I dunno, just the thought of it screams too much work.
i think im really confused right now.. when people swap there engines where do u get ur engines from? most come from rh drive cars to begin with right?
na all i wanna do is swap the engine the transmission. wanted to know what i was getting into since my car is auto this being manual and since the steering rack is on the opposite side i dunno if that would affect it.
you gotta do a manual conversion. Is the shift linkage intact? Do you have axles? the master cylinder and brake booster "should" just swap over to your car. Your going to need a pedal set: clutch, brake, throttle. Shifter assembly.... does any of this stuff come with the clip? And you will likely need a manual ecu.
I got a JDM clip with an LSD tranny for $2750. It had everything minus the lights. The clip should have everything you need to do whatever you want to do. Im 99.9% sure that the pedal assemblies are the same since the JDM and USDM pedals are arranged the same way (clutch on the left and gas on the right). Its always nice to have extra parts
i didnt buy it yet but i would get the whole clip cause it comes with the digital climate control headlights, foglights and a lot of other misc stuff that u wouldnt get when just getting the engine.
My clip did not come with any lights (headlights, foglights, or turn signal lights). Be sure to ask the importer if you will actually get that stuff with your clip. The lights were the only things missing from my clip.
i bought a 94 jdm bb1 h22a 5spd front clip
my car= 94 f22a auto
i used all the engine mounts from the clip
i bought a usdm clutch hardline from majestic hondy
re-use the jdm clutch dampner assembly/rubber line
hell you can even use the jdm clutch pedal assembly with spacers
buy a new master cyl and slave
youll need a usdm brake pedal though
used the jdm shift cables
It just takes more time removing it all from the clip then into your car. I'm very happy i bought the clip because you get sooo much extra parts.
