Quick question on rear sway bar.
Old Sep 14, 2006 | 06:19 PM
EK99hatch's Avatar
Default Quick question on rear sway bar.
I have a 96 civic cx hatch I am going to be installing front/rear gsr brakes shortly. I would like to add a front/rear sway bar setup as well. I know for sure I want the Comptech rear swaybar/tiebar combo. What is a good one for the front? Also what do I order the rear sway bar kit for SI,CX,GSR? I think I will be getting the lca's front and rear as well. I have searched on the topic, I found some posts but, I did not get a clear answer.
Thanks in advance.
Scott
Old Sep 14, 2006 | 06:49 PM
egsleepercivic's Avatar
I would get the SI kit assuming you will use the si lca's, other LCA's may work but I am not positive
Old Sep 14, 2006 | 07:29 PM
BlueIntegraBoy's Avatar
Default Re: (egsleepercivic)
http://www.jdmuniverse.com/for...47935
You can use Si or GSR rear sway bar, as well as ITR.
Old Sep 15, 2006 | 07:32 AM
EK99hatch's Avatar
Default Re: (BlueIntegraBoy)
Thanks for the replies.
kulo
Suspension & Brakes
Oct 2, 2012 12:06 PM
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
racin-type
Apr 23, 2003 04:48 AM
