Suspension & Brakes Theory, alignment, spring rates....
Ground Control break-in period. how long?
Old Sep 14, 2006 | 06:10 PM
el_Presidente's Avatar
Default Ground Control break-in period. how long?
i've read there's a break-in period for ground control coilovers. i have them with konis and have some squeaking coming from the fronts everytime they move. i'm assuming this is the breaking-in as i just installed this past weekend. anyone know how long this period lasts? i'm really hoping the squeaking will go away. and is there a quick fix to that?
Old Sep 15, 2006 | 05:55 AM
:Andrew's Avatar
Default Re: Ground Control break-in period. how long? (el_Presidente)
i have never heard it called a break in period. but yes that squeaking will go away
Old Sep 15, 2006 | 06:37 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Ground Control break-in period. how long? (:Andrew)
Yeah, I've never heard of a "break-in" period either. Your best bet would be to contact GC directly though.
Old Sep 15, 2006 | 08:43 AM
CelicaGTV6's Avatar
I'm guessing the sound you hear is the upper spring mount grinding against the upper shock mount. As a spring compresses, it rotates slightly. So when you hit bumps in the road, or the like, the spring compresses slightly which causes the upper spring mount to rotate slightly. The mount rotates against the non-moving shock mount, and the result is the noise you hear.
The fix is pretty easy: apply some high pressure grease to the mating surface between the top of the spring perch and the bottom of the shock mount.
Old Sep 15, 2006 | 12:17 PM
Tyson's Avatar
id like to know where youve heard gc has a break in period.
Old Sep 16, 2006 | 01:08 AM
i guess nevermind about the "break-in" period. not exactly sure where i heard that from. maybe i was thinkin of something else, who knows. thanks for the replies.
Old Sep 16, 2006 | 01:27 AM
enviousdm's Avatar
I recently installed GCs w/ tophats and Koni yellows on my DC and i am getting the squeaking sounds also, but its coming from the rear. It got worse after I took it in for a 4wheel alignment. This will go away also?
Old Sep 16, 2006 | 06:39 AM
Dwight Schrute's Avatar
Default Re: (CelicaGTV6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CelicaGTV6 &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing the sound you hear is the upper spring mount grinding against the upper shock mount. As a spring compresses, it rotates slightly. So when you hit bumps in the road, or the like, the spring compresses slightly which causes the upper spring mount to rotate slightly. The mount rotates against the non-moving shock mount, and the result is the noise you hear.
The fix is pretty easy: apply some high pressure grease to the mating surface between the top of the spring perch and the bottom of the shock mount.</TD></TR></TABLE>
what kind of grease do you use? i have valvoline multi purpose suspension grease that i got from advance auto. it's red.
Old Sep 16, 2006 | 09:57 AM
hayabusa160's Avatar
Default Re: (drewthomas14)
that works i use that grease alot on suspension stuff
Old Sep 16, 2006 | 03:16 PM
enviousdm's Avatar
Ive searched the archives and i see others with my rear squeak suspension problem. None of them state to use the grease. A few problems/fixes i saw were to check the camber kit adjuster to see if it was screwed on tightly and bushings are dried out - so buy a new one.
I doubt it is the camber kit adjuster, so do you guys think its the dried out bushings or the need of grease?
TIA
Oregonized
Suspension & Brakes
Jul 23, 2007 08:24 AM
shyboy817
Suspension & Brakes
Jul 26, 2005 01:09 PM
RineRacing
Feb 17, 2004 08:55 AM
LX4CYL
Dec 30, 2003 05:38 AM
EFSiR
Sep 24, 2003 10:34 PM
