OVERHEATING!!!
overheating will be caused by just a few things.
1) Bad radiator
2) Air in the coolant lines
Replacing your coolant (along with flushing it... can't hurt) will cost you $10-15. A thermostat is (I believe) $20 or so.
A new radiator will cost you $100 or so at Autozone plus new coolant.
1) Bad radiator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 175Shot4Door »</TD></TR><TR><TD CLASS="quote">ok well i turned on the heat and no heat at all just cool air so i heaerd that if i beed the system it wll be ok and can i use water?</TD></TR></TABLE>
if you had no heat it probably means your thermostat is bad and it needs replacing.
It's also possible you have a leak in your coolant system.
Oh, and you can't just use water. you need to mix it 50/50 with antifreeze. Please get a Chilton or Haynes manual when you next go to autozone or wherever you go to get car stuff.
