one headlight dimmer than other
put both new bulbs in and the passenger side headlight is dimmer than the other bulb, tried other bulbs and it does the same thing. Any idea on what might be causing this? I just got this car so not sure whats up with it. its a 98 civc ex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxykid70 »</TD></TR><TR><TD CLASS="quote">check the ground.</TD></TR></TABLE>
x2
x2
here a picture of the plug im having trouble with. Looks like it from another car cause the driver side is the factory one. Ive checked the wires and they seem to be ok, but not sure why its dimmer than the other one.
i checked the connections their fine, i switch 2 of them and that makes the high beams on all the time, they look fine when they on high, but i switch the wires back and its back to the low being dim. the black wire coming off to the side i have no idea, the ground runs in and connects then splices out to the side
going back to grounding, try running that black wire from the harness to the chassis and see if that helps.
and did you install that harness? its not an oem one, so make sure they are wired correctly
ill try regrounding it, but heres some more info on the problem to better understand.
running on low beam the driver side headlight is fine, the passenger side headlight is dim, when you cut to high beam the drivers side goes to high , BUT the passenger side cuts off completely and no light comes out, cut back to low and it comes back on dim.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjim »</TD></TR><TR><TD CLASS="quote">i didnt install the harnes and i checked the wire if i redo the 2 its makes the passenger stay on high beam all the time.</TD></TR></TABLE>
mine did this, it was a fuse.
i would check the fuses.
i also have projectors on mine for now (i know they suck) and one headlight is dimmer than the other because of how they are wired in.
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
I am having a problem like yours. My high beam wire is loose so that is why my high beam doesn't work. But then the headlights will be working and then dim. It looks like I am flashing the headlights. If I were you I would get some new wire, and redo the wiring and see if that helps at all. And clean inside the headlight harness.
