Type-S motor parts Q.....
Old Sep 14, 2006 | 04:00 PM
Revi's Avatar
Default Type-S motor parts Q.....
I got a 5th Gen Type-S motor on the way and i would like to know if all the normal maintanace parts (Water Pump, Oil Pump, distributor cap/rotor) are the same as USDM parts. Im ordering parts from hondaautomotiveparts.com and im just making sure all the parts are the same. I know internally they are not, but is everything external the same? I know this is a noob q but im just making sure.
Old Sep 14, 2006 | 04:49 PM
soundbomber's Avatar
Default Re: Type-S motor parts Q..... (Revi-Ra)
yeah you'll be fine
Old Sep 14, 2006 | 06:12 PM
SteveoBA8's Avatar
Default Re: Type-S motor parts Q..... (soundbomber)
do the h23 manual timing belt tensioner conversion+ t and b belt and balance shaft seal retainer, water pump, check seals before you put it in
Old Sep 14, 2006 | 06:14 PM
fast_honda's Avatar
Damn, clean lude Revi-Ra......those 19's? Luvin it.
headrec*
Apr 25, 2007 03:07 AM
Freshazzburu
Mar 1, 2007 07:37 AM
abeaujuin
Jul 29, 2004 06:47 AM
Nocturnal
21
Mar 29, 2003 02:32 PM
SleepinGSR
May 17, 2002 11:24 PM
