Anyone make the B18C into EG exhaust extension?
Old Apr 29, 2002 | 07:16 PM
B19CivicHB's Avatar
Default Anyone make the B18C into EG exhaust extension?
I just figured that it was such a commonly needed piece that someone\place may fabricate them. Anyone know?
Thanks!
-Nick-
Old May 1, 2002 | 09:07 AM
B19CivicHB's Avatar
Default Re: Anyone make the B18C into EG exhaust extension? (B18CivicHB)
darn...
Old May 1, 2002 | 09:24 AM
WAFFLES's Avatar
I used a gsr midpipe, mugen muffler, itr (usdm) ex. manifold, and a custom straight pipe as my exhaust. I hope thats what you were refering to(the gsr midpipe that is).
Old May 1, 2002 | 02:00 PM
B19CivicHB's Avatar
Default Re: Anyone make the B18C into EG exhaust extension? (WAFFLES)
Im talking about the little 4" section that is needed at the bottom of the downpipe so that the gsr cat connects to the civic exhaust. Ive always been told its too short without getting an extension fabricated.
Old May 2, 2002 | 02:23 AM
b19coupe's Avatar
Get the little 4" pipe from a 92-93 Integra 4 door. It fits between the A-pipe and the catalytic converter. It also has the fitting for the oxygen sensor. I had to use it when I was using the DC GSR header on my B18C swap in my EG coupe. Or use a Type-R header, it's 4" longer than the GSR one and has the fitting for the oxygen sensor.
Old May 2, 2002 | 02:50 AM
rainforest's Avatar
Default Re: Anyone make the B18C into EG exhaust extension? (b19coupe)
just go to a exhaust shop and have them do it its cheap enough.
Old May 2, 2002 | 06:32 AM
Kalokohan's Avatar
New User
Mine actually bolted up because ImportAutoSalvage sent me a 95LS cat which was long enough to bolt right up to my exhaust. 00B18C1 in a 93 hatch. I still had to get CDE to install it with new seals though.
Old May 2, 2002 | 08:35 AM
92sleepR's Avatar
New User
Default Re: Anyone make the B18C into EG exhaust extension? (Guardson3r3)
I wish i'd known that trick when i did my swap. I wouldn't have that ghetto hack job that i've yet to fix
Mike
nandos91crx
Aug 23, 2011 07:48 AM
BlackCivicEX
Aug 9, 2011 03:47 PM
egciviccx
Apr 8, 2003 03:29 PM
Colin
Feb 13, 2003 01:41 PM
