test pipe resonator....
how come its for off road use only...does that mean everytime im autocrossing i have to switch it back? what happens if i use it just for street use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erck »</TD></TR><TR><TD CLASS="quote">how come its for off road use only...does that mean everytime im autocrossing i have to switch it back? what happens if i use it just for street use</TD></TR></TABLE>
They say that just to cover their own asses. Almost every aftermarket part is labeled " for off road use only"
It is illegal..... and it is not emissions friendly.....
..personally, it is not worth putting a "tees pipe" on accord.... it's too much car for such a piece of crap of catalitic converter replacement ...(..talk about a bad replacement....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erck »</TD></TR><TR><TD CLASS="quote">so its all good if i drive it on the highway...will it still pass emmission tests? is it steet legal?</TD></TR></TABLE>
let's say if you remove your lung and put a supermarket plastic bag into your body, will they work the same?
you don't have to replace it everytime but if you get caught by the poo poo, good luck, you are looking at 600-1000 in fine plus smog ref.(if there's emission law in IL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">
Not to mention it's and ABSOLUTELY USELESS piece of metal.
Header...... yeah.... it's a good mod...
You will feel the difference right away when you install one..... just be sure you get a 4-2-1 instead of some 4-1.. because that could weaken the car a little bit... ...knowyahmean?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline »</TD></TR><TR><TD CLASS="quote">Header...... yeah.... it's a good mod...
You will feel the difference right away when you install one..... just be sure you get a 4-2-1 instead of some 4-1.. because that could weaken the car a little bit... ...knowyahmean?!</TD></TR></TABLE>
this man speaks the truth.
ok good....now to completely change the subject....is it hard to install lowering springs....i got the headers, your right i do feel the difference, took your advice and got the 421
Walterronny
Welding / Fabrication
Apr 16, 2013 02:37 PM
ITR1148
Aug 23, 2007 06:35 PM
