solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe???
Old Sep 14, 2006 | 10:57 AM
B18 CYA's Avatar
Default solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe???
ok so you guys know the main relay problem EFs have? well the same sorta thing is happening except with my fuel pump. i replaced the main relay already and stilll happens.
once in a while the if you turn the car off and try to turn it back on, you get a solid engine code and the fuel pump wont prime.
NOW THE FIRST TIME I STARTED UP THE NEW MOTOR, i heard some crazy *** clicking coming from under the dash, (sounded like fuse box area) is there any relays there that can crap out or something? one time i kicked the fuse box in anger, the code went away, fuel pump primed and i was able to start the car..so it isnt an issue with the ecu.
help me out guys i need to drive !!
Old Sep 14, 2006 | 11:18 AM
B18 CYA's Avatar
Default Re: solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe??? (B18 CYA)
ahh someone needs to know!!
Old Sep 14, 2006 | 11:53 AM
turboflush's Avatar
I am in a similar situation. I think it is the ignition switch (only puts out 8v to the relay). read my post that got pushed to the bottom.
Old Sep 14, 2006 | 12:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Check fuse #14 labeled alternator,solenoid valve...
It provides power to the main relay..
Old Sep 14, 2006 | 12:20 PM
B18 CYA's Avatar
Default Re: solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe??? (88DXCRX)
all my fuses are fine. it just happened yesterday again. got pulled over by the police, went to start my car after and no fuel pump priming, and the engine light stay on its like theres no power going to it now or something
Old Sep 14, 2006 | 12:32 PM
ITR97-143's Avatar
sounds like you have a Grounding issue... check all your grounds to the body.
Old Sep 14, 2006 | 12:41 PM
B18 CYA's Avatar
Default Re: solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe??? (ITR97-143
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR97-143 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you have a Grounding issue... check all your grounds to the body.</TD></TR></TABLE>
ok i will check, i know the ones under the hood are all good, but is there any other ones i should check for? under the dash, under the car by the pump? etc.
Old Sep 14, 2006 | 02:11 PM
B18 CYA's Avatar
bump for answers
Old Sep 14, 2006 | 04:40 PM
B18 CYA's Avatar
Old Sep 14, 2006 | 05:03 PM
slowassciv33's Avatar
same problem but wit an integra...the clickin from the main relay??? its starts to click then my pump primes...everyone tellin me its a main relay problem
Old Sep 14, 2006 | 05:11 PM
user 72830283's Avatar
i'm in the same boat.... just that my fuel pump won't prime at all..all my ground are good..my main relay is good and tested in my other chassis, the fuking fuel pump refuses to prime..
Old Sep 14, 2006 | 05:16 PM
didyouhearthat's Avatar
The fuel pump relay is located to the left of the steering wheel in the dash. If it is getting hot and failing, that could be your problem. (or is it a diff relay?)
*If that is the main relay, then solder the points on it again and see what happens.
Old Sep 14, 2006 | 06:36 PM
ITR97-143's Avatar
Default Re: solid engine code, fuel pump wont prime???? same kinda problem as main relay maybe??? (didyouhea
well one sure fire way to test your fuel pump would be to take out your back seat and hot wire the leads. to 12volts if it dosent work then you need to crawl under the car and pull the tank and replace the pump
Old Sep 15, 2006 | 08:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR97-143 &raquo;</TD></TR><TR><TD CLASS="quote">well one sure fire way to test your fuel pump would be to take out your back seat and hot wire the leads. to 12volts if it dosent work then you need to crawl under the car and pull the tank and replace the pump</TD></TR></TABLE>
you're talking about the yellow-balck wire rite? just run a direct 12volt to that?
Old Sep 15, 2006 | 05:44 PM
B18 CYA's Avatar
so yah it was the main relay *shakes head* had to re solder the whole thing it was all cracked.
Old Sep 16, 2006 | 12:04 PM
sry to hear thats mine was a bad ground wit the thermostate wire
guy in a jetta
Nov 7, 2017 12:05 PM
Finnish_Racer
May 31, 2010 05:20 AM
rdeezy78
Nov 27, 2007 02:03 PM
charjacq
Mar 11, 2004 02:06 PM
RenoRacing
Sep 8, 2002 09:41 PM
