FS: Misc. stuff im my garage...
Got to get rid of this stuff so I can get my car in there easily. Pics if needed upon request.
D series a/c compressor (has been modified to work on b series /ac bracket) it will still work on the d series bracket as well. Worked perfectly when removed
oem gsr intake manifold (has IAT sensor still on it)
A/C condenser ( i also have 2 a/c condenser fans. one is almost brand new)
2000 SI stock axle back exhaust ( good condition)
LS longblock with p30 pistons ( has gsr water pump, and brand new gsr timing belt on it . ready for ls/vtec. The only problem is one cylinder reads very low compression. But the other 3 read in the 180 to 200psi range.)
OEM Honda d series obd2 alternator ( recently purchased about 5 months ago)
OEM B series cam gears
4 4x100 steelies with tires ( about 75% tread left on tires
Just send me a offer on everything. I have more to come. Just need to look around
Modified by :Andrew at 3:12 PM 9/14/2006
Modified by :Andrew at 3:14 PM 9/14/2006
Modified by :Andrew at 4:22 PM 9/14/2006
Modified by :Andrew at 9:46 AM 9/21/2006
greddy2smoke
Jul 12, 2007 05:31 PM
