Need Help identifying Skunk 2 stage 3 cams
Old Sep 14, 2006 | 07:09 AM
Player5530's Avatar
Default Need Help identifying Skunk 2 stage 3 cams
Hi I found a set of skunk2 stage 3 cams and I would like to know how I would go about identifying these cams so I don’t get scammed. I did a couple of searches and I found nothing. Is there any markings or numbers that would identify these cams as original skunk 3's. I have Toda B's in my car right now and I know on the distributor side of the cam both cams have a letter B on it to show that they are toda B's.
Thanks.
Old Sep 14, 2006 | 08:31 AM
Player5530's Avatar
i know there are people out there that have these cams. can any give me a little help
Old Sep 14, 2006 | 02:25 PM
BfromSD's Avatar
Default Re: Need Help identifying Skunk 2 stage 3 cams (Player5530)
get a micromiter(spelled wrong) and check to lobe higth with the listed Skunk2 ones
Old Sep 14, 2006 | 04:26 PM
Player5530's Avatar
Default Re: Need Help identifying Skunk 2 stage 3 cams (spicyEM1)
i picked up one today im going to check the measurements of the vtec lobe against skunk2 's specs . thanks
Old Sep 14, 2006 | 04:32 PM
NA_B18C1's Avatar
they should have numbers ingraved on the intake side by the distributor. at least that's what i have on mine
Old Sep 14, 2006 | 05:56 PM
Player5530's Avatar
Default Re: (NA_B18C1)
what numbers do u have engraved on urs
Old Sep 14, 2006 | 06:06 PM
Skunk2Tony's Avatar
On the intake cam there will be a "S08" etched on and on the exhaust there will be an"s10". Hope this helps.
Old Sep 14, 2006 | 06:17 PM
b19coupe's Avatar
Default Re: Need Help identifying Skunk 2 stage 3 cams (Skunk2Tony)
How would you know noob?
Welcome to H-T.
Old Sep 14, 2006 | 06:25 PM
Skunk2Tony's Avatar
Default Re: Need Help identifying Skunk 2 stage 3 cams (b19coupe)
hmm, lets just say im associated with the company. Thanks for the welcome. Just trying to help out where i see fit.
Old Sep 14, 2006 | 06:32 PM
b19coupe's Avatar
lol- I have heard of you. I hear that you are an o.k. driver We need all the help we can get here.
Old Sep 14, 2006 | 06:40 PM
Skunk2Tony's Avatar
lol, funny my friends all say that too. Just saw a need for some facts and stepped in. Hope the info helped.
Old Sep 18, 2006 | 08:18 AM
Player5530's Avatar
thanks for your help I'll look for the markings on the cams. Thanks
Old Sep 18, 2006 | 08:20 AM
Player5530's Avatar
Quick question will that be on the distributor side of the cam or will it be in the middle of the cam between one of the cam lobes
Old Sep 18, 2006 | 08:25 AM
b19coupe's Avatar
Distributor end.
Old Sep 18, 2006 | 10:14 AM
Player5530's Avatar
thanks
Old Sep 20, 2006 | 04:43 PM
NA_B18C1's Avatar
Default Re: (Player5530)
threre should be some numbers ingraved on both camshafts. if you aren't sure..call skunk2 and give them the numbers so they can tell you if it's their's or not or what type of specs the cams are
austinwasthere
Jun 17, 2014 11:58 AM
jdmcx
Jan 5, 2004 06:58 AM
riceball777
Oct 19, 2003 09:53 PM
EBPSI
Jan 29, 2003 07:56 AM
Rembrant Q. Einstein
May 20, 2002 11:47 PM
