I hate water!!!!!
Old Sep 14, 2006 | 06:56 AM
RedRocketDX's Avatar
Default I hate water!!!!!
My 98 dx hatch is leaking a lot of water into my spare-tire well. I dont think it's my tail lights. Help me!
Old Sep 14, 2006 | 07:32 AM
nighttrain33's Avatar
Default Re: I hate water!!!!! (RedRocketDX)
Mine does that sometimes too, although not very often since I don't drve it when it rains out now. I was thinking about putting on the stuff that they sell for truck beds, duraliner. Maybe I will do that today and let you know how it goes. It seems like it should keep the water out.
-Shane
Old Sep 14, 2006 | 07:57 AM
Kruzen510's Avatar
Has your car been in any previous accidents? How are your seals?
Old Sep 14, 2006 | 08:23 AM
Default Re: I hate water!!!!! (Kruzen510)
The car has no accidents and everything is in mint condition (reason I bought it) with 101,000kms. The seals are nice and fresh and I can tell that it is not leaking from the actual hatch or seals. The first time I found out I took apart the tail lights right away and ran silicone around them. It almost looks like it could be coming from the black snorkel thing under the left tail light but I'm not sure how. If anyone else has had this problem and knows how to fix it please let me know.
Old Sep 14, 2006 | 08:32 AM
Kruzen510's Avatar
Get inside the back of the car and shut the hatch. Have someone else on the outside with a garden hose(or whatever) and completely spray down the back of the car, watch for leaks. Most the time you can spot where the water is coming in. btw... its a lot easyer with all the back interior trim removed, or pulled back so you can see everything.
Old Sep 14, 2006 | 09:15 AM
mikesEK's Avatar
my 97 ek did the same thing ,,it was hands down the tail lights,, i fixed no more problems
any chance someone rolled or worse cut the fenders??I've seen thins done before and water was slung in the cargo area from the tires ,,if i'm not making sence I'l break it down further ,,,,but i think i'm clear
g'luck ...latyer
Old Sep 14, 2006 | 09:25 AM
djsire's Avatar
Default Re: (mikesEK)
i had two leaks. 1 from the rear window. i used rvt sealeant.
and one form under the rear wheel well. it would thro water up in there when i was driving,
Old Sep 15, 2006 | 06:46 AM
HondaHeddie's Avatar
Default Re: (djsire)
buy some silicon spray lube (not grease)
soak your rubbers
let soak in
soak them again
let soak in
....repeat as needed
this will restore the rubber seals
they shrink with age
do not use rtv
Old Sep 15, 2006 | 06:48 AM
BLUE EH3's Avatar
Help we my pennies
DRILL A HOLES IN THE WELL
Old Sep 15, 2006 | 07:27 AM
Earthworm Jim's Avatar
Why not just get a water hose and pour water on the top of your car and find out for yourself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">DRILL A HOLES IN THE WELL</TD></TR></TABLE>
Old Sep 15, 2006 | 07:49 AM
-Gary-'s Avatar
Default Re: I hate water!!!!! (BLUE EH3)
Note to self: Never buy a car from him.
Old Sep 15, 2006 | 07:55 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: I hate water!!!!! (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">
Note to self: Never buy a car from him.</TD></TR></TABLE>
Word.
Old Sep 15, 2006 | 09:05 AM
instrument's Avatar
speaking of drilling a-holes.....
Old Sep 16, 2006 | 08:21 AM
BLUE EH3's Avatar
Help we my pennies
i drilled 3-4 tiny holes in the spare tire well. then i rubberize my hatch/trunk
Old Sep 16, 2006 | 09:34 AM
b16ej1lsd's Avatar
your a moron
why didn't you just fix the real problem instead of covering it up with another problem?
Old Sep 16, 2006 | 09:37 AM
POE's Avatar
POE
Default Re: (b16ej1lsd)
SO many honda's have this issue, most of the time , the gasket or seal for the trunk or window or hatch or tailight's go bad after man years of use/ oxygen drying them out, and became brittle and broken.
Old Sep 16, 2006 | 07:28 PM
numero sete's Avatar
I used to have that problem in my EJ hatch.
It was my tailights. This was back in the fall of last year. Now I hear water slushing around when i brake abruptly or slow down. But the thing is theres no water in my trunk or anywhere to be found?
Any ideas? Sorry for thread jacking but it seemed to be along the same lines...
Old Sep 16, 2006 | 07:37 PM
passthebuck's Avatar
my sparetire tub fills with water too. I found a fix to it here:
https://honda-tech.com/zerothread?id=885253
travisallenn's Avatar
Default Re: (numero sete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numero sete &raquo;</TD></TR><TR><TD CLASS="quote">I used to have that problem in my EJ hatch.
Any ideas? Sorry for thread jacking but it seemed to be along the same lines...</TD></TR></TABLE>
KATRINA KAR!
actually i have no clue, but water is heavy...get rid of the water asap and performance might increase from weight savings
i hope i dont have this problem with my coupe, hasnt rained yet but i will be checking when it does
Old Sep 17, 2006 | 12:55 AM
hatch96y7's Avatar
Default Re: (travisallenn)
water i most likely getting in from ur wing on the hatchback mine is doing the exact same thing and i dont know how to fix it
Old Sep 17, 2006 | 06:41 AM
But the thing is there is no visible water?
Its just the noise of water waving about in my car. At first i thought it was my gas tank i was hearing cuz i removed my rear seats and all but that made no sense...
bcrosby51
Aug 9, 2007 11:48 AM
jamal-188
Apr 9, 2005 07:47 AM
Stoich
Oct 28, 2004 02:21 PM
oMek
Apr 19, 2004 07:29 PM
