Slipping out of gear, shift linkage problem?
Old Sep 13, 2006 | 11:40 PM
Bob_760's Avatar
Default Slipping out of gear, shift linkage problem?
I finally got my CRX back together with some hasport mounts and a 93 GS-R YS-1 trans, the trans has no grinds, shifts very smooth at all rpms, however it sometimes slips out of 2nd and 4th.... I had allways thought popping out of gear was usually a synchro problem, but the synchros feel fine when going into gear. The shifter on my car feels really wierd, it allways has (it was swapped when I bought it) I don't know anything about the shift linkage or the short throw shifter it has except that it worked fine with the random mounts/SiR Y1 the car used to have and never slipped out of gear. Could this problem be due to the shift linkage/shifter or is there somthing wrong with the trans? I'm leaning twards getting Hasport shift linkage and a new short shifter anyway but I'd like to know if anyone has any experience with this. Also can anyone reccomend a good shifter?
Thanks,
-Kurt
Old Sep 14, 2006 | 07:04 AM
QuarterMileMaster's Avatar
Default Re: Slipping out of gear, shift linkage problem? (Bob_760)
I've always heard of these problems being due to bad bearings in the transmission...
Old Sep 14, 2006 | 10:29 AM
civickiller's Avatar
Default Re: Slipping out of gear, shift linkage problem? (QuarterMileMaster)
popping out of gear can be a sign your low on tranny fluid. try and check that
Old Sep 14, 2006 | 10:34 AM
crx_88_si's Avatar
but the fact that the two gears are the farthest from the trans i would measure the linkage.
call hasport and ask for measurements so u can match yours.
Old Sep 14, 2006 | 12:50 PM
Bob_760's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">but the fact that the two gears are the farthest from the trans i would measure the linkage.
call hasport and ask for measurements so u can match yours. </TD></TR></TABLE>
That's what I was thinking... *crosses fingers*
Old Sep 14, 2006 | 01:09 PM
Bob_760's Avatar
Default Re: (Bob_760)
So does anyone have any reccomendations for a shifter? Should I just get some sort of stock shifter or is there a good short throw?
Old Sep 14, 2006 | 02:20 PM
i would recommend a stock one
Old Sep 14, 2006 | 09:58 PM
Bob_760's Avatar
Default Re: (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">i would recommend a stock one
Just a stock CRX shifter, or would some other stock honda shifter be better?
Old Sep 14, 2006 | 10:26 PM
just keep your stock crx shifter
Old Sep 15, 2006 | 09:58 PM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">just keep your stock crx shifter</TD></TR></TABLE>
Just figured I'd ask as I don't have a stock crx shifer... So now I gotta go find one...
So has anyone else had this problem and know the cause? Anything besides trans rebuild ? I'm gonna get some hasport linkage and probably a shifter of some sort soon but I'd like as much info about it as possible.
Also I JUST put the trans on so I just filled it with 2 quarts of BG Synchroshift so I assume its full but I may pick up another quart and get the car nice and square since no trans fluid leaked out when I filled it it may not be quite all the way full...
Old Sep 16, 2006 | 08:20 AM
mahatma's Avatar
yeah you just need to filler up!
Old Sep 16, 2006 | 04:28 PM
Bob_760's Avatar
Default Re: (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">yeah you just need to filler up!</TD></TR></TABLE>
I really hope you're right after the $$$ and time I just got done spending on all that lol...
Old Sep 16, 2006 | 09:09 PM
IndySporty's Avatar
always fill till she leaks back meng! And yeah x2 on the stock shifter. I have actually broken a short shifter in half at the ball trying to run from the cops one night. It was bad.
Old Sep 18, 2006 | 05:44 PM
Bob_760's Avatar
Default Re: (IndySporty)
YES!!!!! I filled it up (it took a quart more!! ) and now it shifts sooooooooooooooooooooooooooooooo smooth. My hasport linkage is allready on the way but hey it couldn't hurt to have the right length linkage anyway. I'll see if i can find a stock shifter next time im at a junk yard but i'm not too worried about it now that it shifts nice. Thanks for all the help guys, i figured my trans was messed up and i was just wishfully thinking i could do somthing to fix it but nope.
'95 BA8
Jun 18, 2010 06:46 AM
tomy_r
Dec 8, 2005 10:15 PM
BrokenLimits
11
Dec 7, 2005 09:34 AM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
