help with my Ls v-tech
Old Sep 13, 2006 | 06:58 PM
blkteg95's Avatar
Default help with my Ls v-tec
i need some help on finding and getting good quality parts that make good hp, i have a b 18a built by whitfield racing, with 12 to 1 comp. ariaz pistons,and am looking to build my head but dont know what is best! i am going to run itr cams and cam gears, what valve trainset up should i go with. and should i get my head milled?
Modified by blkteg95 at 8:27 PM 9/15/2006
Old Sep 13, 2006 | 08:15 PM
tensixty's Avatar
Celebrating 35yrs of Barbie
Default Re: help with my Ls v-tech (blkteg95)
Stick with the tYpe ARH, because vtecH kicks in on the 2nd ring as opposed the b16 it kicks in on the third ring yO!
Old Sep 13, 2006 | 08:50 PM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkteg95 &raquo;</TD></TR><TR><TD CLASS="quote">i need some help on finding and getting good quality parts that make good hp, i have a b 18a built by whitfield racing, with 12 to 1 comp. ariaz pistons,and am looking to build my head but dont know what is best! i am going to run itr cams and cam gears, what valve trainset up should i go with. and should i get my head milled?</TD></TR></TABLE>
If you're running ITR cams all you need is ITR valvetrain. BTW v-tech is spelled vtec. You're gonna get a lot of **** if you don't spell it like that.
Old Sep 13, 2006 | 09:23 PM
qfast817's Avatar
Default Re: help with my Ls v-tech (three stars, two bars)
[QUOTE=three stars, two bars]
If you're running ITR cams all you need is ITR valvetrain..[/QUOTE
i ran type r cams on my stock gsr head i had no problems
Old Sep 14, 2006 | 03:26 AM
LS2ner's Avatar
it shouldnt be a big problem if it is a problem at all. The more aggresive lift and duration on the ITR cams is the reason dual valve springs are suggested. When in higher RPM's you run a higher chance of having valve float.
Old Sep 14, 2006 | 06:27 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: (LS2ner)
You don't have to upgrade the valve train, you'll be fine with ITR cams. I would go with the Blox Type A cams, they are cheaper and better than ITR, the have a higher lift and duration.
Old Sep 14, 2006 | 06:33 AM
DC2 Mang's Avatar
Default Re: (Kiniku Chunks!!!)
I would build the head with more agressive cams that would obtain the most power out of the fully built block
upgraded valvetrain would be required to run cams such and skunk2 stage 2's, blox type B's, buddy club spec 4's and you will easily break the 200 whp mark
Eg_6ness
11
Nov 19, 2010 06:12 PM
blkteg95
Sep 14, 2006 03:30 PM
Mike banX
Oct 20, 2004 07:47 AM
importlegions
20
Jun 25, 2004 10:13 AM
unKnown
Oct 17, 2001 02:11 PM
