civic si radio question
Old Sep 13, 2006 | 05:14 PM
beefjerky's Avatar
Default civic si radio question
just installed the si radio into my car. the problem is that everytime i turn my car off for like 5 minutes and turn it back on i have to program the code in again. its a pian because all your radio presets get lost. does anyone know how to fix this problem?
Old Sep 13, 2006 | 05:26 PM
IheartFLATblack's Avatar
Default Re: civic si radio question (beefjerky)
You probably don't have the constant 12v (commonly called the "memory" wire) hooked up. Check your wiring again. If you need, I can give you a diagram of 99 - 00 Civic stereo wiring.
Old Sep 13, 2006 | 05:29 PM
beefjerky's Avatar
Default Re: civic si radio question (IheartFLATblack)
you know what can you do that please? im kind of stuck
Old Sep 13, 2006 | 05:49 PM
bsixteen's Avatar
i had the same problem when i first bought my car. the wiring was all effed and the dash and tach lights wouldn't come on when i started the car and turned on the lights. i told the dealership to fix it before i bought it. i ended up just buying an alpine cd player ///\lpine ftw
Old Sep 13, 2006 | 06:10 PM
L33TsAbabyEater's Avatar
Default Re: (bsixteen)
Remove the radio and make sure your power wire and memory/ACC are correct...
Old Sep 13, 2006 | 06:18 PM
JSPECSIR's Avatar
Default Re: (DoraThaMuthaF*ckinExplora)
are you talking about a 99-00 si or a 92-95 si.^^^ that plug is for a 98 down honda. some of the wire colors are probably the same though. hers the 2000 wire colors. if you need them.^^^ that might have been all you needed.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Audio
[PRINT THIS PAGE]
Radio 12v white/blue + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- blue/green - gray/black +,- radio harness
RF Speaker +/- red/green - brown/black +,- radio harness
LR Speaker +/- blue/yellow - gray/white +,- radio harness
RR Speaker +/- red/yellow - brown/white +,- radio harness
Old Sep 13, 2006 | 08:59 PM
beefjerky's Avatar
99 si
Blue00Si
Sep 28, 2007 08:21 AM
dogbiscuit
Mar 20, 2006 07:59 AM
Dnycest
Audio / Security / Video
Feb 24, 2006 05:40 AM
davken1102
Apr 25, 2004 11:46 AM
CharmCity
Mar 12, 2003 06:56 AM
