What do you guys do first when braking?
Old Sep 13, 2006 | 04:04 PM
b20acura's Avatar
Default What do you guys do first when braking?
been driving manual for about 1 year. was wondering what all of you do first when braking. do you guys clutch first or brake first? my friend told me to brake first because i will always have control of my car until im fully stopped. just wanted to know
Old Sep 13, 2006 | 04:07 PM
lVlemphizStylez's Avatar
Default Re: What do you guys do first when braking? (b20acura)
i clutch in...coast with no gears engaged...if i need control...i release the clutch
Old Sep 13, 2006 | 04:10 PM
Dogginator's Avatar
Daisy... Daisy...
I just don't think about it and it happens naturally. My driving isn't choreographed.
Old Sep 13, 2006 | 04:15 PM
atg1290's Avatar
Default Re: What do you guys do first when braking? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I just don't think about it and it happens naturally. My driving isn't choreographed. </TD></TR></TABLE>
AHhaha, i usually clutch, coast, brake..
Old Sep 13, 2006 | 05:05 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura &raquo;</TD></TR><TR><TD CLASS="quote">been driving manual for about 1 year. was wondering what all of you do first when braking. do you guys clutch first or brake first? my friend told me to brake first because i will always have control of my car until im fully stopped. just wanted to know </TD></TR></TABLE>
Brake first. Use the engine compression for free braking power, saves the brakes from unnecessary wear, and most Honda engines run no fuel when engine braking anyway, so its even less gas use then pressing in the clutch (minimal gains though).
I'll usually do a rev matched downshift first, then brake in gear, and press the clutch when the engine is around idle rpm in whatever gear the first downshift leaves me.
Really though, the proper procedure is brake, heel and toe downshift rev matching while still braking, until stopped in first gear.
Old Sep 13, 2006 | 09:51 PM
jdmboi510's Avatar
clutch, let it roll on neutral then brake......
Old Sep 13, 2006 | 10:20 PM
bg-33p's Avatar
Default Re: (jdmboi510)
i usually clutch in, holding down clutch and press brake at the same time, is this bad?
Old Sep 14, 2006 | 03:36 AM
IHTFP's Avatar
Default Re: (teggysue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggysue &raquo;</TD></TR><TR><TD CLASS="quote">i usually clutch in, holding down clutch and press brake at the same time, is this bad?</TD></TR></TABLE>
not as long as your clutch is adjusted properly and completely disengages when the pedal is pressed
Old Sep 14, 2006 | 04:23 AM
civic91's Avatar
Brake first then clutch to downshift.
Old Sep 14, 2006 | 06:19 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Clutch, coast brake. We are not driving at LEMANS so use normal driving techniques
Old Sep 14, 2006 | 07:23 AM
JoePSI's Avatar
Default Re: What do you guys do first when braking? (Kiniku Chunks!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Brake first. Use the engine compression for free braking power, saves the brakes from unnecessary wear, and most Honda engines run no fuel when engine braking anyway, so its even less gas use then pressing in the clutch (minimal gains though).
Really though, the proper procedure is brake, heel and toe downshift rev matching while still braking, until stopped in first gear.</TD></TR></TABLE>
Lol you're right but its so annoying when you ride with someone who drives like that,my friend drives like hes driving an indy car on the street.
I personally deploy my parachute whenever i need to break. You know you gotta stop fast when you live your life a quarter-mile at a time.
Old Sep 14, 2006 | 07:52 AM
crx_88_si's Avatar
i just brake and let the engine come down w/ engine braking until like 1500 or 1000 rpm then clutch in.
u use more gas idling then engine braking.. (the momentum of the car spins the motor.)
Old Sep 14, 2006 | 07:58 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (crx_88_si)
If coming to a stop I put the car in neutral and apply the necessary amount of brake. If slowing down for traffic but not stopping, I will downshift to the correct gear and rev match. No need in downshifting all the way to stop the car for a red light. The brakes were put on the car for a reason, might as well use them.
Old Sep 14, 2006 | 08:04 AM
S1NFUL RL1 619's Avatar
Default Re: (SlammedDC2)
kick push, kick push, kick push, kick push... COASSSSTTTT.
i don't think about it... i'm too lazy so i just take the car out of gear, and use my breaks.
Old Sep 14, 2006 | 08:43 AM
honda genome
Guest
Posts: n/a
omfg.....are you kidding me?
Old Sep 14, 2006 | 12:07 PM
CAVTECSol's Avatar
just use the brakes until you feel the engine start to give a little hint of shudder, then clutch in. you actually save gas by keeping it in gear during the stop. the amount of fuel needed to keep the engine running with no application of the throttle at 3000rpm is less than the amount of fuel needed to idle the engine.
Old Sep 14, 2006 | 12:15 PM
Yemdogg's Avatar
Default Re: (CAVTECSol)
^seriously? how is that?
Old Sep 14, 2006 | 01:30 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Yemdogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAVTECSol &raquo;</TD></TR><TR><TD CLASS="quote">just use the brakes until you feel the engine start to give a little hint of shudder, then clutch in. you actually save gas by keeping it in gear during the stop. the amount of fuel needed to keep the engine running with no application of the throttle at 3000rpm is less than the amount of fuel needed to idle the engine.</TD></TR></TABLE>
Do you really think it will save you enough that you will ever notice?
Old Sep 14, 2006 | 01:56 PM
gogogomoveit's Avatar
Default Re: What do you guys do first when braking? (TunerN00b)
Ditto. I will heel toe 1 or 2 gear down, and shift straight to neutral before stop. It depends.
Clutch in first is obviously wrong .
1. Didnt make use of the help of engine braking ( not always a good idea tho)
2. If you suddenly need power, you are out of gear.
Its not even Lemans technique, its common sense.
The emphasis of braking/shifting footwork goes a lot way. Learn it right. BRAKE always comes in first, and is the most important part. IF you have doubt, look at videos (BM or hot version), or pick up a driving technique book written by a race driver.
John 07
Nov 24, 2008 04:11 PM
Slidin'Sidewayz
Honda Motorcycles
16
May 20, 2008 03:00 PM
powerdbygarrett
Oct 17, 2007 07:42 AM
MisterNiceGuy
Honda Civic (2006 - 2015)
14
Aug 19, 2007 07:10 PM
