91 crx si shell, 97 civic ex, 929rr, ge sleeved builf block, lsvtec
i am selling everything that has to do with hondas that i have. i am moving in 15 days and will not have a garage. also selling to put a down payment on a g35.
97 civic ex runs great but needs exhaust and secondary o2. oil pan leaks but is fine to drive for days at a time without topping off oil. ac works mint and all acc work fine. may need a new radio. its lowered on neuspeed springs and has powder coated hx rims with azenis on them. also has city lights and painted head light housings. asking 4k
91 crx si shell exterior is in mint shape but needs a passenger side fender NO ROT. interior is also mint but has some mold from sitting so long. all new brembo cross drilled and slotted rotors, omni control arms in the rear, wire tuck started, no heat or ac was all removed for weight savings but to look as normal as possible. new energy suspension bushings tokico 5 way adj with springs, hasport shift linkage and possibly hasport mounts.. if interested lmk $1700 with everything for b series swap
only rust/rot on the whole car!!
00 cbr 929rr newer pilot power tires, frame sliders and vince and hines slip on. left side has some scratches. just did a 520 conversion 1 down and 2 up in the rear also did the stator. $5200
ls ge sleeved block with eagle rods, cp pistons, new acl bearings, new type r water pump, aebs main studs, crank has been polished and every thing was balanced. professionally built by a local engine builder. Assembly alone was 1k asking $2700
also have a b16 head with cams, valve cover, vtec solenoid, and hondata intake manifold gasket $425
ge ls vtec kit opened but never used with 84 mm head gasket with head studs $315
full hasport mount kit for a b series in an ef
dc sports exhaust for crx
Modified by erebunicrx at 3:52 PM 9/14/2006
Modified by erebunicrx at 4:31 PM 9/14/2006
Modified by erebunicrx at 6:43 PM 9/14/2006
Modified by erebunicrx at 8:47 PM 9/15/2006
Modified by erebunicrx at 5:50 PM 9/16/2006
