wire tuck question
Old Sep 13, 2006 | 11:27 AM
DC2 Mang's Avatar
Default wire tuck question
I am in the process of making a tuck harness
my question is how do you get the main connectors that come out from the firewall that the engine harness plugs into back behind the firewall? or where they can be hidden to be out of sight?
thanks in advance
Old Sep 13, 2006 | 01:11 PM
DC2 Mang's Avatar
Default Re: wire tuck question (DC2 Mang)
bump
Old Sep 13, 2006 | 08:08 PM
DC2 Mang's Avatar
Old Sep 14, 2006 | 06:28 AM
DC2 Mang's Avatar
blah
Old Sep 14, 2006 | 06:58 AM
H8 O ATE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">I am in the process of making a tuck harness
thanks in advance</TD></TR></TABLE>
If I am understanding your question correctly there are a few ways:
1. Most of the time they are put in a strategic location in the bay to hide them, This way there is hardly any extension of wires needed.
2. then there are the cases where someone will remove the pins from the connector, pull the wires thhrough and put the pins back in. Usually you have to extend more wires this way.
3. Then there are the cases where a COMPLETE custom harness is used and then you can pick where you want the bulky connectors in line...
Hope this helps
Old Sep 14, 2006 | 07:18 AM
DC2 Mang's Avatar
Default Re: wire tuck question (8 O ATE)
I noticed that where wire from the connectors lead into the fire wall that there is a large rubber plug
so can I pull the plug out and will the connectors fit through that part of the firewall?
Old Sep 14, 2006 | 07:24 AM
H8 O ATE's Avatar
are you talking about the plugs that go to the ECU?
Old Sep 14, 2006 | 07:36 AM
DC2 Mang's Avatar
im talking about the connectors that are in the egine bay and connect to the engine harness, ill post pics up in a minute of what I want to do and where i want to know if i can pull them through
hmtcrxsir
Appearance Build Threads
Jan 25, 2010 08:41 AM
DrGrEeNtHuMb
Apr 4, 2008 11:05 AM
aaj23
Jun 28, 2003 08:36 PM
