What compression should my engine be at?
Old Sep 13, 2006 | 10:27 AM
square_1's Avatar
Default What compression should my engine be at?
I am going to do a routine compression test in a little bit. What number range is probably healthy for a stock D15 with 200,000 miles?
And I know that is doesn't nessacarily matter how high the numbers are, just as long as they are all uniform, but I know that there probably is a healthy range.
A year ago I compression tested an it was all within the 160 range I think.
Thanks...
Old Sep 13, 2006 | 10:52 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: What compression should my engine be at? (square_1)
Nominal=185 psi
minimum=135 psi
maximum variation between cylinders=28 psi
{info from '88 Factory service manual}
Compression should be tested with engine at operating temperature,
All spark plugs should be removed before testing..
Good Luck,
Old Sep 13, 2006 | 11:35 AM
janz3n's Avatar
what happens if theres more then 28psi difference in one or more cylinders?
Old Sep 13, 2006 | 12:21 PM
88DXCRX's Avatar
Default Re: What compression should my engine be at? (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">any variance between cylinders means a greater variance in the output of the individual cylinders. Simply stated, the engine is rougher than it needs to be if the compression ratios are not balanced between the cylinders.</TD></TR></TABLE>
It may cause the engine to run rough,be unstable,have drive-ability
problems etc..
Old Sep 14, 2006 | 08:36 AM
square_1's Avatar
Default Re: What compression should my engine be at? (88DXCRX)
Yeah, I heard it was something like there shouldn't be a 10 percent difference. So like if there are two that are 155 then the others shouldn't be like 15 less or more or whatever. But 28 psi sounds good too!
So if normal PSI is 185 then how much should it be at right now and still be healthy?
Old Sep 14, 2006 | 08:42 AM
hybrid1990crx's Avatar
I have a d16a6 that was in my old 91 si, and I then bought back later after I did a swap for the kid I sold it to. But when I did a compression test on it, it was 205 across the board with a Snap-On compression guage.
Old Sep 14, 2006 | 09:29 PM
square_1's Avatar
Default Re: What compression should my engine be at? (hybrid1990crx)
Wait, but wouldn't the compression on that be different then my stock D15B2 though?
Old Sep 15, 2006 | 02:08 PM
yeah probably. my b16 put 190 across the board.
range hadies
Mar 25, 2012 12:18 PM
turbotime
Oct 1, 2005 08:46 AM
crxvtecturbo
Feb 7, 2005 06:20 PM
Jonathan_ED3
Oct 28, 2004 03:31 PM
RACEPAK
Jun 12, 2004 01:29 PM
