D-series swap ?
Old Sep 13, 2006 | 09:38 AM
jdm236's Avatar
Default D-series swap ?
Hello H-T gurus, i recently blew the engine in my 97 civic ex( d16y8, with 202,xxx) and i was wondering if a 92-95 jdm d15 would swap over considering its an Obd-1, also car is an automatic so i only need the engine any help would be appreciated
Old Sep 13, 2006 | 09:39 AM
-Gary-'s Avatar
Did you search under the sticky?
https://honda-tech.com/zerothread/878010
Old Sep 13, 2006 | 09:49 AM
jdm236's Avatar
Default Re: (-Gary-)
believe me i have been searching and asking people, considering im only in highschool and money is limited im doing alot of re-search before i invest my money.
Old Sep 13, 2006 | 10:00 AM
TayStew's Avatar
im on my 2nd d15b7 (92-95 DX coupe). my first one blew the first day i got the car, bad ring lands, spun bearings, etc... put a baseball sized hole out the front of the block.
my 2nd d15b7 is doing better, but it is still obvoius these lack in longevity. i got this 2nd motor as fresh as i could find, and 3 months later, its trying to crap out on me.
dont spend money on crap man, just my opinion.
but to answer your question, it is relatively simple to convert obd1 to obd0 (pre-obd), i dont see why it would be much different to convert obd2 to obd1. good luck with a swap.
Old Sep 13, 2006 | 10:02 AM
SHG_Beans's Avatar
Default Re: (TayStew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TayStew &raquo;</TD></TR><TR><TD CLASS="quote">im on my 2nd d15b7 (92-95 DX coupe). my first one blew the first day i got the car, bad ring lands, spun bearings, etc... put a baseball sized hole out the front of the block.
but to answer your question, it is relatively simple to convert obd1 to obd0 (pre-obd), i dont see why it would be much different to convert obd2 to obd1. good luck with a swap. </TD></TR></TABLE>
how badly do you beat the **** out of your motors geez?
Old Sep 13, 2006 | 10:15 AM
nighttrain33's Avatar
You can buy OBD2-OBD1 conversion harnesses just about anywhere. I mean, any aftermarket shop can get you one. Heck, check in classifieds here. I know there are tons of people on here that either have one, can get you one, or can make you one.
-Shane
Old Sep 13, 2006 | 10:27 AM
-Gary-'s Avatar
Default Re: (jdm236)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm236 &raquo;</TD></TR><TR><TD CLASS="quote">believe me i have been searching and asking people, considering im only in highschool and money is limited im doing alot of re-search before i invest my money.</TD></TR></TABLE>
Just an FYI, I wasn't trying to come off as a dick, I was trying to help.
Old Sep 13, 2006 | 04:13 PM
jdm236's Avatar
i dont even care if some1 is a dick they also give info and make me laugh
Old Sep 13, 2006 | 04:48 PM
screwcitycoupe's Avatar
Default Re: D-series swap ? (jdm236)
Why not just look for a USDM Y8 and stick that in there? Direct replacement. No swapping ecu harnesses or worries accessory(power steering, A/C) fitment. You should be able to get a Y8 longblock under $500 with pretty low mileage.
Old Sep 13, 2006 | 05:31 PM
IheartFLATblack's Avatar
I agree with screw city. To run an OBD1 motor in an OBD2 car, you'd probably have to use the OBD1 motor harness and the corresponding ecu. Or you could swap all the sensors over from the obd2 motor to the obd1 motor. Only thing is that obd1 motors dont have crank angle sensors. So in conclusion, try to find a single cam obd2.
Stopsign32v
30
Mar 17, 2009 11:04 PM
iM x Omar
58
Sep 15, 2008 11:46 AM
ownage
May 29, 2008 02:09 PM
jdm236
Oct 15, 2006 01:13 PM
