fuel system to rich
Old Sep 13, 2006 | 08:28 AM
jdlaurs's Avatar
Default fuel system to rich
I have a 2000 GS-R. I changed the O2 senor out back in june. I still have the check engine light coming on and i have a couple of troblue codes. Here they are. P0170 Fuel Trim Malfunction and P0172 System too rich. I called the dealership and they have yet to get back to be on this. There is a problem with the vtech cause it wants to kick in at 4500 rpm's. Can help me please
Old Sep 13, 2006 | 08:42 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: fuel system to rich (jdlaurs)
Was is a direct OEM replacement sensor or a cut and re-wire one. If it is a four wire one, you probably wired it wrong, or you did not do a good job or wiring it. It happened to my boy. Everything was fine for a minute then the acura started acting up and sure enough it was the O2 sensor.
Good luck fixing it.
Old Sep 13, 2006 | 08:46 AM
jdlaurs's Avatar
it was a cut and wire and i wired it how its suppose to go.
Old Sep 13, 2006 | 11:21 AM
HoUTX98GSR's Avatar
Default Re: (jdlaurs)
always go OEM on those things... aftermarket sensors are peices of poo... and btw your VTEC is supposed to kick in at 4400 rpm's
Perfectionist
Oct 8, 2006 02:00 PM
acurakid6786
Feb 10, 2005 10:00 AM
BoostedGSRBubble
Mar 24, 2003 08:46 AM
hybrid22l
Sep 27, 2001 08:22 PM
