Koni G/C install Trouble!!!
Old Sep 13, 2006 | 08:11 AM
redrelease's Avatar
Default Koni G/C install Trouble!!!
I am installing a set of koni yellows and G/C setup, well, when i got the driver side rear, the bolt was a bit tough and not co-operating. Anyways, I stripped the threads on the shock....
My question is, do i have to order a new shock?? or can i put a self-locking nut and let it go? i want it to be safe, i really don't want the bolt to come out when i'm driving, that would be bad....
Old Sep 13, 2006 | 08:20 AM
Fuster_Cluck's Avatar
Default Re: Koni G/C install Trouble!!! (redrelease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrelease &raquo;</TD></TR><TR><TD CLASS="quote">or can i put a self-locking nut and let it go? </TD></TR></TABLE>
How would you do that? The shock has the threaded nut on the rear side which is stripped, right?
I say take the shock to a machine shop and see what they can do for the threads.
I screwed the threads on the camber bolt the other week while changing my suspension out (same set-up as you). I was able to get the bolt back in good enough for the time being:
Old Sep 13, 2006 | 09:01 AM
Archidictus's Avatar
Unceasing Measure
To the OP: use an air grinder to get rid of the welded nut and you can use a locking nut in its place without a problem. I've done it many a time when that particular component becomes damaged.
To the guy above me: drill and rethread that hole you stripped bigger so you don't have to worry about pulling that loose under conering or droop. That's a pair of bolts that could ruin your day in a hurry
Old Sep 13, 2006 | 09:42 AM
Sleepy_Red_hatch's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">To the OP: use an air grinder to get rid of the welded nut and you can use a locking nut in its place without a problem. I've done it many a time when that particular component becomes damaged.
To the guy above me: drill and rethread that hole you stripped bigger so you don't have to worry about pulling that loose under conering or droop. That's a pair of bolts that could ruin your day in a hurry </TD></TR></TABLE>
word. ask me how i know. good thing my car was on blocks
Old Sep 14, 2006 | 12:56 PM
redrelease's Avatar
Well, I ended up cuttin off the weld-on nut and using a self-locking nut. I am still a bit worried about how well the nut will hold on ( 5 Auto-X a year and daily driving.
Old Sep 14, 2006 | 01:12 PM
alacard's Avatar
Default Re: (redrelease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrelease &raquo;</TD></TR><TR><TD CLASS="quote">Well, I ended up cuttin off the weld-on nut and using a self-locking nut. I am still a bit worried about how well the nut will hold on ( 5 Auto-X a year and daily driving.</TD></TR></TABLE>
if you are worried about it, then take the shock to a machine shop (like earlier stated) and have them weld on a new nut. when i installed my koni's....one of the nuts was welded off-center...i ended up just forcing the bolt in..:-/ maybe koni needs to step up on their nut-welding
QKRTHNU
Suspension & Brakes
12
Aug 11, 2012 05:20 AM
shabam
Suspension & Brakes
May 2, 2009 05:41 PM
jsi
May 29, 2005 11:04 AM
racekar
20
Jun 19, 2004 05:12 PM
