Clutch won't bleed
Does anyone know why i can't get my clutch blead? It will start to, and then it will lose a little pressure, then build back up, but it won't bleed fully. I checked the clutch line and don't see or can't feel any fluid anywhere. I am DOT 3 brake fluid. Anyone know what it could be? Thanx
make sure you have 2 people doing it
you sit in the car and pump it about 10 times then hold it to the floor while you have a friend loosen the valve and after he has closed it then raise the clutch and reapeat
just make sure to not let off the pedal while the valve is open
Rhythm Racer
20
Jul 7, 2003 11:24 AM
