Oil restrictors that dont cost $30?
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">whats the lever thingy? is it to control flow?
Yep
Yep
Forget that lever deal... then you really need a gauge to monitor it or just tweak it until you "think" you have it right.
Just get an inline fitting....
http://www.wicksaircraft.com/c...75089
Will cost you like 8 bucks shipped and then just drill the hole out a hair, I want to say a 1/16th drill bit will do the job? Search around for the ideal size, i don't trust my memory on the drill size. Its a brass piece, so the hole is very very easy to drill.
Then you have something you install and never have to think about again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickwhips.com »</TD></TR><TR><TD CLASS="quote">you only really need them if you run a -4an oil line
if you run a -3an oil line you are fine</TD></TR></TABLE>
Even on motors seeing 80+psi? I have a standard bearing t04e that I want to put on, wont that be too much pressure?
I got a stealthmode oil line kit from LSD motorsports. I don't know what size it is...
Even on motors seeing 80+psi? I have a standard bearing t04e that I want to put on, wont that be too much pressure?</TD></TR></TABLE>
what are you soooooooooo worried about. i see a new thread on here everyday, and its your whinny *** worring about something else..... WTF.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster »</TD></TR><TR><TD CLASS="quote">
I got a stealthmode oil line kit from LSD motorsports. I don't know what size it is...</TD></TR></TABLE>
Should be -3an from the block to the turbo. That's what I have!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">dturbocivic- if it bothers you, dont click on my threads. simple concept.</TD></TR></TABLE>you got a point
I have heard of people just putting a spot weld on the turbo oil fitting and then drilling it out to the size they want. If you have a welder and a drill then its a free oil line restrictor
this one is 21 shipped but its nice imo, low profile. I tried apt turbo restrictor+1/8" to 1/4" bushing + 1/8" to -3an 90 and it hit my manifold.
http://cgi.ebay.com/ebaymotors...photo
I need to post a pic of my setup. I have a vf39 subaru turbo on my honda and i couldn't find a m10x1.5 to -3an fitting to save my life. So I went ahead and used the stock vf39 banjo bolt and ordered a 90 degree banjo to -3an fitting. Works great and since its a banjo bolt its pretty much like having a built in restrictor. The bolt hold is tiny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Forget that lever deal... then you really need a gauge to monitor it or just tweak it until you "think" you have it right.
Then you have something you install and never have to think about again.</TD></TR></TABLE>
yes USE This drill out to 1/16 and you are good to go!!!!!!
If you are running a -3 you shouldn't need a restrictor on a journal bearing turbo.
Or you jsut use the stock fitting that goes into your turbo and you hit it flat on with a hammer and the center folds/presses in
Then you take your 1/16" drill and drill through it
I went from 45psi at the turbo to 15-17 and it only took about 30 min. and it was free....
[QUOTE=Boosted Chemist]this one is 21 shipped but its nice imo, low profile. I tried apt turbo restrictor+1/8" to 1/4" bushing + 1/8" to -3an 90 and it hit my manifold.
Wow, that is really nice! For pics for people that didn't check it out:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">what are you soooooooooo worried about. i see a new thread on here everyday, and its your whinny *** worring about something else..... WTF..... </TD></TR></TABLE>
so true...
geoffrey... relax man. it's not that serious. i told you you should be fine.
so true...
Don't buy into that 3-an line BS and you'll be fine. Just spend the extra money and get a restrictor. It won't hurt anything, and it gives you piece of mind.
Make your own!!!!!
Check out my post in this link on how to>>>>
https://honda-tech.com/zerothread/1743481
